Crucial 8GB DDR3-1866 1.35v SO-DIMM Memory
£40.84
29 in stock
Delivery:
Standard: 1-3 working days
  • Type: DDR3 SDRAM
  • Capacity: 8GB
  • Connection: SO-DIMM 204-pin
  • Speed: 1866MHz
  • Data Integrity: Non-ECC
Product codes
In short, 204-pin small outline dual inline memory modules (SODIMMs) are the form factor used to provide DDR3 memory modules for notebook computers and other small form factor computing platforms. 204-pin SODIMMs are currently available in PC3-8500 (DDR3 1066MHz) and PC3-10600 (DDR3 1333MHz) speeds.
To use DDR3 memory, your system must have both a 204-pin SODIMM slot and a chipset that supports DDR3 memory. A DDR3 SODIMM will not fit into DDR2 or DDR memory sockets.
SODIMMs are smaller and thinner than regular DIMMs, and the 204-pin SODIMM PCBs are always ~2.6 inches long and are usually around 1.18 inches high (though the heights can vary slightly). They consist of a number of memory components (usually black) that are attached to a printed circuit board (usually green). The number of memory components on a 204-pin SODIMM’s printed circuit board (PCB) can vary, but the PCB will always have 102 pins on the front and the back both, for a total of 204 pins. The gold pins on the bottom of the SODIMM provide the connection between the memory module and the memory socket.
Product Description Crucial - DDR3 - 8 GB - SO-DIMM 204-pin - unbuffered
Product Type RAM memory
Capacity 8 GB
Memory Type DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type Generic
Data Integrity Check Non-ECC
Speed 1866 MHz (PC3-14900)
Latency Timings CL13
Features Low Voltage, unbuffered
Voltage 1.35 V
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Crucial 8GB DDR3-1866...
£40.84
