Crucial 8GB DDR3 PC12800-1600MHz SoDimm Crucial Dual Voltage
£58.99
36 in stock
Delivery:
Standard: 1-3 working days
  • Type: DDR3L SDRAM
  • Capacity: 8GB
  • Connection: SO-DIMM 204-pin
  • Speed: 1600MHz
  • Data Integrity: Non-ECC
Product codes
Help your laptop perform at its best. Designed to help your laptop run faster and smoother, a Crucial memory upgrade is one of fastest, most affordable, and easiest ways to improve your system's performance. Crucial memory empowers your laptop to achieve faster application loading times, faster system responsiveness, and increased ability to multitask and handle data-intensive programs. What does this mean? Spend less time staring at loading screens and more time getting stuff done. Crucial laptop modules are rigorously tested at both the component and module levels to ensure that your memory meets the stringent compatibility and performance standards. Every module Crucial manufactures is inspected by the Systems Compatibility Group before it leaves the doors. At a fraction of the price of your laptop, an investment in Crucial memory helps your system get up to speed.
Product Description Crucial - DDR3L - module - 8 GB - SO-DIMM 204-pin - unbuffered
Product Type Memory module
Capacity 8 GB
Memory Type DDR3L SDRAM - SO-DIMM 204-pin
Upgrade Type Generic
Data Integrity Check Non-ECC
Speed 1600 MHz (PC3-12800)
Latency Timings CL11
Features Unbuffered
Voltage 1.35 V
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Crucial 8GB DDR3 PC128...
£58.99
