Crucial 8GB DDR3L 1600 MT/s (PC3-12800) DR x8 ECC SODIMM 204p...
Crucial 8GB DDR3L 1600 MT/s (PC3-12800) DR x8 ECC SODIMM 204pin CL11
£89.74
Delivery:
Standard: 1-3 working days
Product codes
Crucial 8GB DDR3 PC3-12800 Unbuffered ECC 1.35V 1024Meg x 72 204-pin SODIMM DDR3 204-pin SODIMM: Approximately 2.66 in. by 1.18 in. (66 mm by 30 mm)
In short, 204-pin small outline dual inline memory modules (SODIMMs) are the form factor used to provide DDR3 memory modules for notebook computers and other small form factor computing platforms. 204-pin SODIMMs are currently available in PC3-8500 (DDR3 1066MHz) and PC3-10600 (DDR3 1333MHz) speeds.
To use DDR3 memory, your system must have both a 204-pin SODIMM slot and a chipset that supports DDR3 memory. A DDR3 SODIMM will not fit into DDR2 or DDR memory sockets. (Information about which memory technology your system uses is included in the Crucial Memory Advisor™ tool.)
SODIMMs are smaller and thinner than regular DIMMs, and the 204-pin SODIMM PCBs are always ~2.6 inches long and are usually around 1.18 inches high (though the heights can vary slightly). They consist of a number of memory components (usually black) that are attached to a printed circuit board (usually green). The number of memory components on a 204-pin SODIMM's printed circuit board (PCB) can vary, but the PCB will always have 102 pins on the front and the back both, for a total of 204 pins. The gold pins on the bottom of the SODIMM provide the connection between the memory module and the memory socket.
  • ECC: ECC
  • Kit Qty: 1
  • Speed: 1600 MT/S
  • Tracer: False
  • Voltage: 1.35V
  • DIMM Type: Unbuffered
  • Bullet Features: Increases system performance
Crucial - DDR3 - 8 GB - SO-DIMM 204-pin - unbuffered
RAM memory
8 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11
Unbuffered
Voltage
1.35 V
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Crucial 8GB DDR3L 1600...
£89.74
