Crucial 8GB Kit (2x4GB) DDR3 1600 MT/s (PC3-12800) CL11 Unbuf...
Crucial 8GB Kit (2x4GB) DDR3 1600 MT/s (PC3-12800) CL11 Unbuffered
£96.04
Delivery:
  • Type: DDR3 SDRAM
  • Capacity: 8GB
  • Connection: DIMM 240-pin
  • Speed: 1600MHz
  • Data Integrity: ECC
Product codes
Crucial 240-pin DIMMs are used in DDR3 memory for desktop computers. DDR3 is the latest generation of memory with an improved architecture that allows it to transmit data more quickly.
A dual inline memory module (DIMM) consists of a number of memory components (usually black) that are attached to a printed circuit board (usually green). The gold pins on the bottom of the DIMM provide a connection between the module and a socket on a larger printed circuit board. The pins on the front and back of a DIMM are not connected to each other.
Each 240-pin DIMM provides a 64-bit data path (72-bit for ECC or registered or Fully Buffered modules).
To use DDR3 memory, your system motherboard must have 240-pin DIMM slots and a DDR3-enabled chipset. This is because a DDR3 SDRAM DIMM will not fit into a standard DDR2 DIMM socket or a DDR DIMM socket.
The number of black components on a 240-pin DIMM can vary, but it always has 120 pins on the front and 120 pins on the back, for a total of 240. 240-pin DIMMs are approximately 5.25 inches long and 1.18 inches high, though the heights can vary. While 240-pin DDR3 DIMMS, 240-pin DDR2 DIMMs, 184-pin DDR DIMMs, and 168-pin DIMMs are approximately the same size, 240-pin DIMMs and 184-pin DIMMs have only one notch within the row of pins.
Product Description Crucial - DDR3 - 8 GB: 2 x 4 GB - DIMM 240-pin - unbuffered
Product Type RAM memory
Capacity 8 GB: 2 x 4 GB
Memory Type DDR3 SDRAM - DIMM 240-pin
Upgrade Type Generic
Data Integrity Check ECC
Speed 1600 MHz (PC3-12800)
Latency Timings CL11
Features Single rank, Low Voltage, unbuffered
Voltage 1.35 V
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Crucial 8GB Kit (2x4GB...
£96.04
