We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
BLS2K16G4D32AEST is a 32GB Kit consisting of (2) 16GB DDR4 desktop modules that operates at speeds up to 3200 MT/s and has a CL16 latency. It is an Unbuffered DIMM. It conforms to the industry standard DDR4 UDIMM layout of 288 pins and is compatible with systems that take DDR4 3200MT/s UDIMM memory. Add Ballistix Sport AT memory into your build and instantly fire up your gaming performance. Loaded with an arsenal of density and speed, Sport AT DDR4 modules help give you the fast, smooth performance you need to build with authority and successfully complete your gaming missions. Style meets substance in Sport AT memory, so your build looks and plays great - especially with ASUS TUF Gaming motherboards. Game like a boss and equip your rig with Ballistix Sport AT memory.
Product Description | Ballistix Sport AT - DDR4 - kit - 32 GB: 2 x 16 GB - DIMM 288-pin - 3200 MHz / PC4-25600 - unbuffered | Product Type | Memory kit | Capacity | 32 GB: 2 x 16 GB | Memory Type | DDR4 SDRAM - DIMM 288-pin | Upgrade Type | Generic | Data Integrity Check | Non-ECC | Speed | 3200 MHz (PC4-25600) | Latency Timings | CL16 (16-18-18) | Features | Heat sink, dual rank, dual channel, Intel Extreme Memory Profiles (XMP 2.0), TUF Gaming Alliance certified, AMD Ryzen Ready, unbuffered | Voltage | 1.35 V | Manufacturer Warranty | Limited lifetime warranty (Germany - 10 years) |
General | |
Width | 136 mm |
Height | 34.9 mm |
Weight | 35 g |
Memory | |
Type | DRAM memory kit |
Technology | DDR4 SDRAM |
Form Factor | DIMM 288-pin |
Module Height (inch) | 1.37 |
Chips Organization | X8 |
Voltage | 1.35 V |
Miscellaneous | |
Colour Category | Black |
Compliant Standards | Plug and Play |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty (Germany - 10 years) |
Shipping Dimensions (WxDxH) / Weight | 178 mm x 11.1 mm x 127 mm / 114 g |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
