Crucial DDR3 16GB 2 x 8 GB SO-DIMM 204-pin 1600 MH
£83.06
Delivery:
Standard: 1-3 working days
Key features
  • Increases system performance
  • Compatible with Mac systems
  • Every single module extensively tested at the component and module level for functionality
  • Meets or exceeds Apple's own quality requirements
  • Easy installation
  • Available in DDR2 and DDR3 SODIMMs in capacities up to 8GB
  • DDR3 modules include lead and halogen-free technology
  • Limited lifetime warranty
  • Type: DDR3 SDRAM
  • Capacity: 16GB
  • Connection: SO-DIMM 204-pin
  • Speed: 1600MHz
  • Data Integrity: Non-ECC
Product codes
Engineered to be compatible with your Apple system, Crucial Memory for Mac takes the guesswork out of a memory upgrade. Since Apple systems often have very specific memory requirements, including particular component densities, speeds, and SPD programming specifications, it's important to buy your memory from people who know Apple computers inside and out. With over a decade of experience manufacturing and developing memory for Apple systems, Crucial makes it easy to find memory that's been designed specifically for your system.
If you're an Apple computer user, you probably expect intuitive, reliable performance from your system. Crucial thinks memory should work the same way, too. For each module it manufactures, Crucial sends it through a rigorous testing process to ensure that you're getting a reliable, high-performance memory solution. Every module that leaves the doors has been extensively tested at the component level for voltage and temperature resistances, signal integrity, and software compatibility. Even better, Crucial modules are lead and halogen-free (DDR3 modules only). The result? Reliable memory that meets or exceeds Apple's own memory requirements.
Unsure how to install memory or have an important question about your Apple system? Let the team of experts help! With a tech-savvy team that's well-versed in Apple systems, Crucial will provide the technical support you need - no matter how old your Mac computer gets. From phone support, videos, FAQ articles, and do-it-yourself guides, Crucial has got the resources you need to keep your system up to speed.
Crucial is a trusted name when it comes to DRAM, and that's no coincidence. As a brand of Micron, one of the largest manufacturers of DRAM in the world, Crucial works with its engineers to design, refine, test, manufacture, and support an extensive line of memory modules. With a product portfolio that includes more than 250,000 different DRAM upgrades for more than 50,000 systems, Crucial has got one specifically designed for your Mac system. For more than a decade Crucial has kept Mac computer owners happy with high-performance memory and outstanding customer service. No matter what type of Mac system you have, Crucial has got a compatible solution.
Product Description Crucial - DDR3 - 16 GB: 2 x 8 GB - SO-DIMM 204-pin - unbuffered
Product Type RAM memory
Capacity 16 GB: 2 x 8 GB
Memory Type DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type System specific
Data Integrity Check Non-ECC
Speed 1600 MHz (PC3-12800)
Latency Timings CL11
Features Unbuffered
Voltage 1.35 / 1.5 V
Designed For Apple iMac (Late 2011); Mac mini (Mid 2011); MacBook Pro (Early 2011, Late 2011)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Crucial DDR3 16GB 2 x...
£83.06
