Marketing description is not available.
Product Description | Crucial - DDR4 - module - 16 GB - SO-DIMM 260-pin - 2666 MHz / PC4-21300 - unbuffered | Product Type | Memory module | Capacity | 16 GB | Memory Type | DDR4 SDRAM - SO-DIMM 260-pin | Upgrade Type | System specific | Data Integrity Check | Non-ECC | Speed | 2666 MHz (PC4-21300) | Latency Timings | CL19 | Features | Dual rank, unbuffered | Voltage | 1.2 V | Manufacturer Warranty | Limited lifetime warranty (Germany - 10 years) | Designed For | Apple iMac (Early 2019); Mac mini (Late 2018) |
General | |
Capacity | 16 GB |
Memory | |
Type | DRAM memory module |
Technology | DDR4 SDRAM |
Form Factor | SO-DIMM 260-pin |
Module Configuration | 2048 x 64 |
Chips Organization | X8 |
Voltage | 1.2 V |
Miscellaneous | |
Compliant Standards | Lead-Free, halogen-free |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty (Germany - 10 years) |
Compatibility Information | |
Designed For | Apple iMac (Early 2019) , Apple Mac mini (Late 2018) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
