Crucial Micron 5200ECO 7.68TB SATA 2.5" SED
£1,151.23
Delivery:
Key features
  • Fewer servers to accomplish more
  • Storage that scales
  • Form Factor: 2.5"
  • Capacity: 7680GB
  • Interface: Serial ATA-600
  • Type: Internal hard drive
Product codes
There’s an easy way to speed up business-critical workloads that cripple hard drives: The Micron® 5200 series of SATA SSDs. Engineered on industry-leading 64-layer 3D NAND, the Micron 5200 SSD delivers best-in class performance and capacity on the same proven architecture as the 5100 series. Designed for virtualized workloads that power your business, such as OLTP, BI/DSS, VDI, block/object, media streaming and more, the lowlatency Micron 5200 series of SSDs eliminates storage bottlenecks with fast, consistent performance – and a lower total cost of ownership. A single Micron SSD allows you to get 3X more performance than an entire rack of 24 10K RPM hard drives. Imagine the impact — across your entire data centre.
Product Description Micron 5200 ECO - solid state drive - 7680 GB - SATA 6Gb/s
Type Solid state drive - internal - Native Command Queuing (NCQ), Dynamic and Static Wear Leveling, Secure Erase function, Enhanced Power Loss Data Protection, Multi-Word DMA mode 0-2 support, Ultra DMA Mode 0-6 support, PIO mode 3, 4 support, End-to-end data protection, Hot-Plug Support, upgradable firmware
Capacity 7680 GB
Hardware Encryption Yes
Encryption Algorithm 256-bit AES
NAND Flash Memory Type 3D triple-level cell (TLC)
Form Factor 2.5"
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Features Native Command Queuing (NCQ), Dynamic and Static Wear Leveling, Secure Erase function, Enhanced Power Loss Data Protection, Multi-Word DMA mode 0-2 support, Ultra DMA Mode 0-6 support, PIO mode 3, 4 support, End-to-end data protection, Hot-Plug Support, upgradable firmware, S.M.A.R.T.
Dimensions (WxDxH) 69.85 mm x 100.45 mm x 7 mm
Weight 70 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Crucial Micron 5200ECO...
£1,151.23
