Today's data deluge requires a revolutionary way to mine data for insights and turn insights into action. Created to radically accelerate data center applications and workloads, the Micron 9200 series of SSDs combines the capacity of 3D NAND with the proven throughput and response times of the NVM Express (NVMe) protocol to deliver one of the most complete high-capacity, high-performance solutions available. Maximize application throughput and minimize latencies to get faster access to your data - and a powerful business advantage. Available in the U.2 and HHHL form factors in capacities from 1.6TB to 11TB.
Product Description | Micron 9200 PRO - solid state drive - 1.92 TB - U.2 PCIe 3.0 (NVMe) | Type | Solid state drive - internal - Read Unrecoverable Bit Error Rate (UBER) 10e-17, 3D NAND Technology, Flex Capacity | Capacity | 1.92 TB | NAND Flash Memory Type | 3D triple-level cell (TLC) | Form Factor | 2.5" SFF | Interface | U.2 PCIe 3.0 (NVMe) | Features | Read Unrecoverable Bit Error Rate (UBER) 10e-17, 3D NAND Technology, Flex Capacity, S.M.A.R.T. | Dimensions (WxDxH) | 69.85 mm x 100.5 mm x 15 mm |
General | |
Device Type | Solid state drive - internal |
Bytes per Sector | 512 |
Width | 69.85 mm |
Depth | 100.5 mm |
Height | 15 mm |
Performance | |
SSD Endurance | 3.5 PB |
Internal Data Rate | 2.7 GBps (read) / 1.95 GBps (write) |
4KB Random Read | 620000 IOPS |
4KB Random Write | 170000 IOPS |
Expansion & Connectivity | |
Compatible Bay | 2.5" SFF |
Power | |
Power Consumption | 8 Watt (idle) , 25 Watt (active) |
Miscellaneous | |
Compliant Standards | BSMI CNS 13438 Class B, EN55024, ICES-003 Class B, RoHS, UL 60950-1 Second Edition, AS/NZS CISPR22:2006 Class B, IEC60950/EN60950, WEEE 2012/19/EC, KCC KN32 Class B, KCC KN35, VCCI 2015.04 Class B |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 85 °C |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 85 °C |
Humidity Range Operating | 25 - 95% (non-condensing) |
Shock Tolerance (non-operating) | 1500 g @ 0.5 ms half-sine |
Vibration Tolerance (non-operating) | 3.1 g @ 5-800 Hz |
