Crucial MX300 1TB 2.5" M.2 SSD
Product codes
Increase the speed, durability, and efficiency of your system for years to come with the Crucial MX300 SSD. Boot up in seconds and fly through the most demanding applications with an SSD that fuses the latest 3D NAND flash technology with the proven success of previous MX-series SSDs. Your storage drive isn't just a container, it's the engine that loads and saves everything you do and use. Get more out of your computer by boosting nearly every aspect of performance.
Crucial MX300 - solid state drive - 1 TB - SATA 6Gb/s
Solid state drive - internal
1 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
M.2 2280
SATA 6Gb/s
Data Transfer Rate
600 MBps
TRIM support, hardware encryption, Error Correction Code (ECC), Adaptive Thermal Protection, Redundant Array of Independent NAND, Multistep Data Integrity Algorithm, Active Garbage Collection, Extreme Energy Efficiency technology, Data Path Protection, dynamic write acceleration, power loss prevention (PLP), Crucial Custom Firmware, Device Sleep support, S.M.A.R.T.
22 mm x 80 mm x 2.3 mm
3-year warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Crucial MX300 1TB 2.5"...
