0-50% phone battery life restored in just 30 mins
Phone battery about to die? This Fast Travel Bundle will charge your phone up to 3.8 times and can also charge two devices at the same time. Need a quick charge? This power bank fast charges many phones from 0-50% battery life in just 30 mins thanks to 18W charging power from both ports.
Unlock fast charging on your phone
When it comes to fast charging, not all phones are created equal. How fast you can charge a phone is dependent on the charging speed the phone will accept. If your phone accepts a maximum 18W charge, it won't charge any faster if you plug it into a wall charger capable of 100W because the phone dictates the charging speed. For example, iPhones released between the 8 and 11 series, all accept a maximum of 18W fast charging. The same applies for Samsung Galaxy S series between S6 and S20. The last iPhone 12 now accepts 20W maximum fast charging and the latest Samsung Galaxy S21 accepts 25W fast charging. This Fast Travel Bundle includes 2 x fast charging ports, either capable of 18W fast charging for phones. 18W charging power is still regarded as FAST, even when charging the latest iPhone 12 or Samsung Galaxy S21.
USB-C Vs USB-A fast charging
This power bank includes two USB charging ports (1x USB-C, 1x USB-A), both capable of 18W fast charging. The USB-C port uses a fast charing protocol known as Power Delivery (PD), which is a fast charging protocol all phones will accept. USB-A port uses a fast charging protocol known as Qualcomm QuickCharge 3.0 (QC 3.0), which is a fast charging protocol only Android phones will accept, not iPhone. This fast charging rule is common with all 18W USB-A power banks. Therefore, if an iPhone user wants a fast charge, they will need to charge using the USB-C port. If they choose to use the USB-A port, they will receive a 12W charge instead
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
