Unlock fast wireless charging
Unlock our fastest wireless charging speed yet for your devices with our Fast Wireless Bundle. Our fastest wireless charger yet the PrimePro Wireless delivers 15W top-speed wireless charging.
Wirelessly charge your phone or AirPods/earbuds
Wirelessly charge any device that supports Qi wireless charging, including iPhone, AirPods, AirPods Pro and Samsung Galaxy phones. Simply place your device on the charger and our wireless technology will do the rest. Compatible with cases under 3mm in thickness.
Understanding wireless charging
The technical terminology around wireless charging can be confusing, but a simple explanation can give you a general understanding of how it works. Wireless chargers have a coil inside them, which when they are activated (by a device being placed on them) begin to generate power. A wireless compatible device also has a coil inside it which allows it to receive the power generated by the charger. This process only works when the device and the charger are properly aligned with one another, and the charger does not emit wireless power when it is not in use. QI is a commonly used standard in the wireless charging industry that indicates compatibility between a wireless charger and a device. There are a couple of competing standards, but Qi is currently the most popular and widely used
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
