D-Link 1-Port Mini GBIC Module for 1000BaseLX (LC Duplex)
£67.84
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 1000Base-LX port (IEEE 802.3z standard)
  • Fibre type: 9 um single-mode, up to 10 km
  • Wave length: 1310 nm
  • Type: Modules
  • Stock Status: In Stock
Product codes
This transceiver uses the industry-standard Small form Pluggable (SFP) package. It slides into the mini-GBIC slot of the Gigabit device. Like all D-Link mini-GBIC transceivers, it is hot-swappable: you can remove or replace the transceiver with the system powered on, which allows modules to be added or swapped without interrupting the network.
Product Description D-Link DEM 310GT - SFP (mini-GBIC) transceiver module - GigE
Device Type SFP (mini-GBIC) transceiver module - LC
Form Factor Plug-in module
Cabling Type 1000Base-LX
Data Transfer Rate 1 Gbps
Optical Wave Length 1310 nm
Data Link Protocol GigE
Max Transfer Distance 10 km
Designed For D-Link Data Center 10; DES 12XX, 30XX; DGS 12XX, 3100, 32XX, 33XX, 3630; DWS 3024; DXS 1100, 1210, 3400, 3600; L2+ Gigabit Wireless Switch; Web Smart DES-1228, 1252, DGS-1216, 1224, 1248, DXS-1210-12; xStack DES-3526, 3528, 3552, 3828, 3852, DGS-3426, 3427, 3450, 3612, 3627, 3650, DXS-3326, 3350
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
D-Link 1-Port Mini GBI...
£67.84
