The DGS-1210-10/10P/20/28 features a fanless design that allows for quieter operation and helps to extend the device's lifetime. While the DGS-1210-28P/52/52P feature a smart fan design that powers on after the switch reaches a certain temperature, saving energy and cutting costs without sacrificing performance.
Product Description | D-Link Web Smart DGS-1210-10P - switch - 10 ports - Managed | Device Type | Switch - 10 ports - Managed | Enclosure Type | 1U | Subtype | Gigabit Ethernet | Ports | 8 x 10/100/1000 (PoE+) + 2 x Gigabit SFP | Power Over Ethernet (PoE) | PoE+ | PoE Budget | 78 W | MAC Address Table Size | 8K entries | Remote Management Protocol | SNMP 1, SNMP 2, Telnet, HTTP, TFTP | Features | Flow control, full duplex capability, Layer 2 switching, DHCP support, auto-negotiation, BOOTP support, RARP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, port mirroring, Weighted Round Robin (WRR) queuing, store and forward, MAC address filtering, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, Spanning Tree Protocol (STP) support, Access Control List (ACL) support, Quality of Service (QoS), DHCP server, Safeguard Engine | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3at | Power | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) | 33 cm x 18 cm x 4.4 cm | Weight | 1.84 kg |
General | |
Enclosure Type | Desktop 1U |
PoE Budget | 78 W |
Authentication Method | RADIUS |
RAM | 512 KB |
Built-in Devices | Led panel |
Status Indicators | Port transmission speed, power, link OK, link/activity |
Expansion / Connectivity | |
Interfaces | 8 x 1000Base-T RJ-45 PoE+ , 2 x Gigabit LAN SFP |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Miscellaneous | |
MTBF | 205,249 hours |
Compliant Standards | FCC Class A certified, C-Tick, cUL, VCCI Class A ITE, IC Class A |
Dimensions & Weight | |
Width | 33 cm |
Depth | 18 cm |
Height | 4.4 cm |
Weight | 1.84 kg |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 95% |
