D-Link 10-PORT 10/100/1000 PoE+ Smart Switch, Fanless, Rackmo...
D-Link 10-PORT 10/100/1000 PoE+ Smart Switch, Fanless, Rackmountable, 2xSFP Ports
£100.66
12 in stock
Delivery:
Standard: 1-3 working days
Key features
  • D-Link Green technology conserves energy by powering down unused ports, saving you money while reducing your carbon footprint
  • Advanced management functions make for a truly versatile switch that integrates performance and scalability
  • Fully IPv6 compatible and ready for enterprise deployment, giving you a head start on the next Internet standards evolution
  • Type: Gigabit Ethernet
  • Ports: 10
  • Data Transfer Rate: 1Gbps
  • Managed: Yes
  • POE: PoE+
Product codes
The DGS-1210-10/10P/20/28 features a fanless design that allows for quieter operation and helps to extend the device's lifetime. While the DGS-1210-28P/52/52P feature a smart fan design that powers on after the switch reaches a certain temperature, saving energy and cutting costs without sacrificing performance.
Product Description D-Link Web Smart DGS-1210-10P - switch - 10 ports - Managed
Device Type Switch - 10 ports - Managed
Enclosure Type 1U
Subtype Gigabit Ethernet
Ports 8 x 10/100/1000 (PoE+) + 2 x Gigabit SFP
Power Over Ethernet (PoE) PoE+
PoE Budget 78 W
MAC Address Table Size 8K entries
Remote Management Protocol SNMP 1, SNMP 2, Telnet, HTTP, TFTP
Features Flow control, full duplex capability, Layer 2 switching, DHCP support, auto-negotiation, BOOTP support, RARP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, port mirroring, Weighted Round Robin (WRR) queuing, store and forward, MAC address filtering, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, Spanning Tree Protocol (STP) support, Access Control List (ACL) support, Quality of Service (QoS), DHCP server, Safeguard Engine
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3at
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 33 cm x 18 cm x 4.4 cm
Weight 1.84 kg
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link 10-PORT 10/100/...
£100.66
