We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The DXS-1100-10TS 10-Port 10 Gigabit Ethernet Smart Switch provides an entry-level solution for Small and Medium Businesses wishing to deploy 10 Gb Ethernet. 8 x 10 GBase-T ports instantly increases network bandwidth over standard Cat 6a cabling without the need to overhaul existing network infrastructure wiring. 2 x 10 Gigabit SFP+ fiber ports provide additional network connection flexibility.
Product Description | D-Link DXS 1100-10TS - switch - 8 ports - smart - rack-mountable | Device Type | Switch - 8 ports - smart | Enclosure Type | Rack-mountable 1U | Subtype | Gigabit Ethernet | Ports | 8 x 10GBase-T + 2 x 10 Gigabit SFP+ | Performance | Switching capacity: 200 Gbps | Capacity | IGMP groups: 512 , Virtual interfaces (VLANs): 4094 , ARP entries: 128 | MAC Address Table Size | 16K entries | Jumbo Frame Support | 9KB | Routing Protocol | IGMPv2, IGMP, MLDv2, MLD | Remote Management Protocol | SNMP 1, RMON 1, RMON 2, SNMP 3, SNMP 2c, HTTP, TFTP | Features | Flow control, MDI/MDI-X switch, BOOTP support, ARP support, IGMP snooping, DoS attack prevention, port mirroring, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, DHCP snooping, Jumbo Frames support, MLD snooping, Safeguard Engine, D-Link Green Technology, LLDP support, DHCP relay, Port Security, SNMP trap, DHCP client, Loopback, DiffServ Code Point (DSCP) support | Compliant Standards | IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.3ae, IEEE 802.3an, IEEE 802.3az, IEEE 802.1AX | Power | AC 120/230 V (50 - 60 Hz) | Dimensions (WxDxH) | 44 cm x 21 cm x 4.4 cm | Weight | 2.69 kg | Manufacturer Warranty | Limited lifetime warranty |
General | |
Encryption Algorithm | SSL, SSL 3.0, SSL 2.0 |
Flash Memory | 128 MB |
Status Indicators | Port transmission speed, power, link/activity, fan |
Expansion / Connectivity | |
Interfaces | 8 x 10GBase-T RJ-45 , 2 x 10Gbit LAN SFP+ |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V (50 - 60 Hz) |
Power Consumption Operational | 50.9 Watt |
Miscellaneous | |
MTBF | 585,959 hours |
Compliant Standards | VCCI, BSMI, cUL, CB, CCC, FCC, RoHS, RCM |
Dimensions & Weight | |
Width | 44 cm |
Depth | 21 cm |
Height | 4.4 cm |
Weight | 2.69 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Environmental Parameters | |
Min Operating Temperature | -5 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 0 - 95% (non-condensing) |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 0 - 95% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
