D-Link 16-PORT 10/100 EASYSMART SWITC
£53.65
Delivery:
Standard: 1-3 working days
Key features
  • Create a Fast Ethernet network that is easy to setup and managed. Fanless design allows for noiseless operation and at the same time saves energy and cost
  • VLAN support allows you to create separate networks whilst QoS ensures that time sensitive data are prioritised and prevents network bandwidth abuse
  • Powerful switch management functions can be performed through a web management interface or through the SmartConsole Utility
  • Type: Fast Ethernet
  • Ports: 16
  • Data Transfer Rate: 100Mbps
  • Managed: No
  • POE: No
Product codes
The DES-1100 Series Fast Ethernet Smart Managed Switch features a full set of configurable functions that provide strong performance and scalability. With an easy-to-use management interface accessible via a PC utility or web browser, the DES-1100 Series helps customers to quickly and easily deploy their network.
Product Description D-Link EasySmart Switch DES-1100-16 - switch - 16 ports - unmanaged
Device Type Switch - 16 ports - unmanaged
Enclosure Type 1U
Subtype Fast Ethernet
Ports 16 x 10/100
MAC Address Table Size 8K entries
Features Flow control, auto-negotiation, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, Unicast Storm Control, Quality of Service (QoS), bandwidth control
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 28 cm x 12.5 cm x 4.4 cm
Weight 227 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link 16-PORT 10/100...
£53.65
