D-Link 16P switch 14x10G SFP+/2x 10GBase-T/SFP+
£925.11
Delivery:
Standard: 1-3 working days
Key features
  • Switching capacity
  • Heat dissipation
  • Packet buffer
  • Type: Gigabit Ethernet
  • Ports: 16
  • Managed: Yes
  • Stock Status: In Stock
Product codes
The DXS-1100 Series 10 Gigabit Ethernet Smart Managed Switches are a set of Smart Layer 2 10 Gb Ethernet switches that provide an entry-level solution for Small and Medium Businesses (SMB) wishing to deploy 10 Gb Ethernet. These switches are ideal for server farms or as network aggregation devices, and provide a cost-effective and feature-rich solution to 10 Gb Ethernet requirements. The DGS-1100-16SC consists of 14 x 10G SFP+ ports and 2 x 10GBASE-T/SFP+ combo ports.
Product Description D-Link DXS 1100-16SC - switch - 16 ports - smart - rack-mountable
Device Type Switch - 16 ports - smart
Enclosure Type Rack-mountable 1U
Subtype Gigabit Ethernet
Ports 14 x SFP+ + 2 x 10 Gigabit SFP+
Performance Switching capacity: 320 Gbps , Forwarding performance: 238.096 Mpps , Packet buffer size: 2 Mbps
Capacity VLAN groups: 128
MAC Address Table Size 16K entries
Jumbo Frame Support 9KB
Routing Protocol IGMPv2, IGMP, MLDv2, MLD
Remote Management Protocol SNMP 1, RMON 1, RMON 2, SNMP 3, SNMP 2c, HTTP, TFTP
Features Flow control, MDI/MDI-X switch, BOOTP support, ARP support, IGMP snooping, DoS attack prevention, port mirroring, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, DHCP snooping, Jumbo Frames support, MLD snooping, Safeguard Engine, D-Link Green Technology, LLDP support, DHCP relay, Port Security, SNMP trap, DHCP client, Loopback, DiffServ Code Point (DSCP) support
Compliant Standards IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.3ae, IEEE 802.3an, IEEE 802.3az, IEEE 802.1AX
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 44 cm x 25 cm x 4.4 cm
Weight 2.91 kg
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link 16P switch 14x1...
£925.11
