D-Link 24-Port 10/100 Smart III PoE Switch 1000BASE/SFP + 2 G...
D-Link 24-Port 10/100 Smart III PoE Switch 1000BASE/SFP + 2 Gigabit
£194.37
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • New 802.3at PoE+ standard to provide extra power to connected appliances
  • Easily configurable through a web interface
  • Time-based PoE to switch off PoE devices automatically
  • Cable diagnostics function to help troubleshoot wiring problems
  • AutoVoice VLAN for seamless integration with IP telephony
  • Innovative firewall-like ACL to enforce security and access restriction
  • Type: Fast Ethernet
  • Ports: 24
  • Data Transfer Rate: 100Mbps
  • Managed: Yes
  • POE: PoE
Product codes
The DES-1210-28P is the first PoE switch in the Fast Ethernet Smart III series. Equipped with 24 Fast Ethernet ports, 2 Gigabit ports and 2 additional Gigabit copper/fiber combo ports, this switch integrates the features of the successful Smart III series with PoE and the PoE+ functionality. With an easy to use web interface and eco-friendly design, the DES-1210-28P helps customers to quickly and easily deploy their networks, saving energy and money.
The DES-1210-28P is the ideal solution as an advanced edge switch for SMB and enterprise networks. The 4 additional Gigabit ports allow for fast and reliable copper or fiber uplinks to the rest of the infrastructure. The Asymmetric VLAN support will provide access to shared resources such as servers or the Internet, without complicated VLAN configurations. Additionally, the innovative AutoVoice VLAN feature allows for easy integration of 3rd party IP phones, placing VoIP traffic in a separate VLAN, thus ensuring the quality and security of VoIP traffic.
The DES-1210-28P complies with the 802.3af PoE standard, and the recently ratified, high-power 802.3at standard. This gives you extra flexibility at deploying appliances such as wireless Access Points, IP cameras and VoIP phones in your network, even in mix-vendor environments. For added flexibility and power-saving, the DES-1210-28P integrates the Time-Based PoE feature, which turns off the power when it is not needed, for example, at nights or during the weekends. This means that PoE-powered devices which otherwise would be always on, can be switched off centrally, saving power and money.
Product Description D-Link DES 1210 - switch - 24 ports - Managed
Device Type Switch - 24 ports - Managed
Enclosure Type 1U
Subtype Fast Ethernet
Ports 24 x 10/100 + 2 x combo Gigabit SFP + 2 x 10/100/1000
Power Over Ethernet (PoE) PoE
MAC Address Table Size 8K entries
Remote Management Protocol SNMP 1, SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP
Features Flow control, Layer 2 switching, DHCP support, power over Ethernet (PoE), auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, port mirroring, Weighted Round Robin (WRR) queuing, store and forward, MAC address filtering, Broadcast Storm Control, IP address filtering, half duplex mode, full duplex mode, Multicast Storm Control, Unicast Storm Control, SNTP support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), static IP mode, Safeguard Engine
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3at
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 44 cm x 21 cm x 4.4 cm
Weight 2.6 kg
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link 24-Port 10/100...
£194.37
