D-Link 24-Port 10/100Mbps Nway Switch
£42.15
Delivery:
Standard: 1-3 working days
Key features
  • 24 10/100Mbps ports
  • Full/half duplex support for each port
  • MDI uplink port for easy expansion
  • Print jobs
  • Flow control in full duplex mode for protection against data loss
  • Type: Fast Ethernet
  • Ports: 24
  • Data Transfer Rate: 100Mbps
  • Managed: No
  • POE: [N/A]
Product codes
This desktop switch is designed for small offices and larger workgroups.
All ports auto-sense the network speed of the computers and hubs to run at either 10Mbps or 100Mbps. The ports also auto-negotiate between full and half duplex and support flow control. Expansion is easy through a MDI uplink port. You cascade several switches together through this port to get more ports.
IEEE 802.3x Flow Control allows your servers to directly connect to this switch for fast, reliable data transfer.
Product Description D-Link DES 1024D - switch - 24 ports - unmanaged - rack-mountable
Device Type Switch - 24 ports - unmanaged
Enclosure Type Rack-mountable
Subtype Fast Ethernet
Ports 24 x 10/100
Performance Switching fabric bandwidth: 4.8 Gbps
MAC Address Table Size 8K entries
Features Flow control, auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, full duplex mode, Quality of Service (QoS), Energy Efficient Ethernet
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 28 cm x 12.58 cm x 4.4 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link 24-Port 10/100M...
£42.15
