D-Link 24-Port Green Ethernet Copper Gigabit Switch
£71.71
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Power-saving feature, for up to 25%* less power consumption
  • *figure based on a scenario assuming that PCs are used for 10 hours a day, powered off for 14 hours a day and connected to the switch using 20m cables
  • 24 Gigabit Ethernet ports
  • Mounting bracket kit supplied
  • Cable diagnostic function
  • Type: Gigabit Ethernet
  • Ports: 24
  • Data Transfer Rate: 1Gbps
  • Managed: No
  • POE: [N/A]
Product codes
Documents
Computers do not require Internet access all the time; neither do switches utilize all ports at all times. When a computer or network equipment is shutdown, switches often remain on and continue to consume considerable amount of power. With Green Ethernet technology, D-Link switches can automatically detect link status and reduce power usage of ports that are idle. Computers or any connecting parties set to standby mode (not power off), however, will not provide significant power savings.
The Green Ethernet switches have the ability to analyze the length of any Ethernet cable connected to them for adjustment of power usage accordingly. Shorter lengths require less power.
For a traditional switch, power consumption remains constant even when the ports are not in use. In a standard workday scenario where PCs are used for 10 hours a day and powered off 14 hours a day, and connected to the switch using 20 meter cables, D-Link's Green Ethernet can save up to 25% power used for each system.
Get the blazing speed of Gigabit Ethernet with the D-Link GigaExpress DGS-1024D, a 24-port 10/100/1000Mbps Gigabit Switch that delivers power, performance, and reliability in one cost-effective, space-saving design. Increase the speed of your network server and backbone connections, or make Gigabit to the desktop a reality.
Power users in the office, workgroup, or creative production environment can now move large, bandwidth-intensive files faster. Transfer graphics, CGI, CAD, or multimedia files across the network instantly. The versatile and compact 1RU height design of the DGS-1024D enables the device to be rackmounted in a standard 19 inch rack, while conserving valuable rack space.
It features a non-blocking switching architecture that filters and forwards packets at full wire-speed for maximum throughput. An 8K MAC address table provides scalability for even the largest networks. Address learning and aging, 802.3x Flow Control for full-duplex mode, and back pressure flow control for half-duplex mode alleviates traffic congestion and ensures reliable data transmission.
Designed using industry standards, it is compatible with virtually all 10, 100, and 1000Mbps Ethernet devices and other vendor equipment. The D-Link DGS-1024D 10/100/1000 Mbps Gigabit Switch protects your existing network investments while providing you with a straightforward migration path to faster Gigabit speeds.
The auto features of this gigabit switch make installation plug and play and hassle-free. No configuring is required. Auto MDI/MDI-X crossover on all ports eliminate the need for crossover cables or uplink ports. Auto-negotiation on each port senses the link speed of a network device (10, 100, or 1000 Mbps) and intelligently adjusts for compatibility and optimal performance.
It also features diagnostic LEDs which display status and activity, allowing you to quickly detect and correct problems on the network. Every port also supports a cable diagnostic feature that helps to detect cable related problems.
* Product Highlights *
  • Uses up to 45% less energy
  • 48Gbps switching capacity
  • Desktop or rack-mountable design
  • Non-blocking architecture
Product Description D-Link DGS 1024D - switch - 24 ports - unmanaged - rack-mountable
Device Type Switch - 24 ports - unmanaged
Enclosure Type Rack-mountable
Subtype Gigabit Ethernet
Ports 24 x 10/100/1000
Performance Switching fabric bandwidth: 48 Gbps
MAC Address Table Size 8K entries
Jumbo Frame Support 9600 bytes
Features Flow control, auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, full duplex mode, Quality of Service (QoS), Jumbo Frames support, Cable Diagnostics Function, D-Link Green Technology, fanless, Energy Efficient Ethernet
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 28 cm x 18 cm x 4.4 cm
Resources
The following resources are available for the D-Link 24-Port Green Ethernet Copper Gigabit Switch
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link 24-Port Green E...
£71.71
