D-Link 28-Port Gigabit PoE SmartPro Stackable Switch
£525.21
Delivery:
Key features
  • 10G physical stacking and/or uplink eliminates the bottleneck of stacking backbone servers, and storage accesses
  • Intuitive graphical Web UI complete with 10 languages for SMB; Comprehensive Command Line Interface (CLI) and SNMP for Out-of-band console management
  • Wired speed inter-VLAN routing helps by reducing the pressure of routers and backbone networks, improving the overall network efficiency
Product codes
The DGS-1510 series is the next generation of smart managed switch. It contains 16, 24 or 48 10/100/1000 Mbps ports plus 2 Gigabit SFP ports and 2 10G SFP+ ports, 24/48 10/100/1000 Mbps ports plus 4 10G SFP+ ports, as well as one 24 10/100/1000 Mbps PoE plus 2 Gigabit SFP ports and 2 10G ports smart managed switch. With it's 10G SFP+ ports, the DGS-1510 series is ideal for deployments in the SME/SMB core with its 10G uplinks connecting with servers equipped with 10G port connectivity. For medium to large scale enterprise deployment, it can serve as a good interconnection between the core switch and edge switch.
Product Description D-Link SmartPro DGS-1510-28P - switch - 28 ports - Managed - rack-mountable
Device Type Switch - 28 ports - L3 - Managed - stackable
Enclosure Type Rack-mountable 1U
Subtype Gigabit Ethernet
Ports 24 x 10/100/1000 (PoE+) + 2 x Gigabit SFP + 2 x 10 Gigabit SFP+
Power Over Ethernet (PoE) PoE+
PoE Budget 193 W
Performance Switching capacity: 92 Gbps , Forwarding performance: 68.45 Mpps , Stacking bandwidth: 20 Gbps
Capacity ARP entries: 256 , IPv6 routes: 32 , IPv4 routes: 64
MAC Address Table Size 16000 entries
Jumbo Frame Support 9000 bytes
Routing Protocol Static IP routing
Remote Management Protocol SNMP 1, RMON 1, Telnet, SNMP 3, SNMP 2c, HTTP, CLI
Features Flow control, auto-negotiation, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, DoS attack prevention, port mirroring, store and forward, IPv6 support, half duplex mode, full duplex mode, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, Safeguard Engine, Cable Diagnostics Function, bandwidth control, D-Link Green Technology, LLDP support, Link Aggregation Control Protocol (LACP), Energy Efficient Ethernet, Loopback
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.3ae, IEEE 802.1s, IEEE 802.3at, IEEE 802.3az
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 44 cm x 21 cm x 4.4 cm
Weight 2.54 kg
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link 28-Port Gigabit...
£525.21
