D-Link 5 Megapixel Varifocal Bullet Dome Network Camera
£786.62
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • A 5 megapixel sensor provides stunning high resolution images, helping to ensure that you capture the details you need
  • Zoom and focus remotely whilst WDR neutralises imperfect lighting, providing clear images with the right amount of contrast even for backlit subjects
  • An IP66 weatherproof housing with sunshield makes the DCS-7517 ideal for the most demanding of surveillance applications
  • Stock Status: In Stock
Product codes
The D-Link DCS-7517 5 Megapixel Varifocal Outdoor Network Camera is a high definition professional surveillance and security solution. The camera uses a 5 megapixel progressive scan CMOS sensor with a motorized varifocal lens and on-board WDR image enhancement, to deliver truly superior quality video in all conditions.
Product Description D-Link DCS-7517 - network surveillance camera
Device Type Network surveillance camera - fixed - weatherproof
Audio Yes
Weight 1.25 kg
Connectivity Technology Wired
Camera Colour - Day&Night
Optical Zoom 4.3 x
Max Resolution 2560 x 1920
Frame Rate (max) 30 frames per second
Optical Sensor Type CMOS - 1/3.2" - 5 MP
Minimum Illumination 0.5 lux - colour , 0.1 lux - B&W , 0 lux - IR
Focal Length Control Motorized zoom
Focal Length 2.8 mm - 12 mm
Lens Iris F/1.8 - auto iris (DC)
Interfaces Composite video, Ethernet 10Base-T/100Base-TX
Voltage DC 12 V / PoE
Features Date/time stamp, IR filter, auto exposure control, Power over Ethernet, auto gain control, auto white balance
Manufacturer Warranty 5-year warranty
Environmental Parameters (operating) -40 °C - 50 °C; 20 - 80% (non-condensing) relative humidity
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link 5 Megapixel Var...
£786.62
