D-Link 5 Port 10/100/1000 Green Ethernet Gigabit Desktop Switch
TOP QUALITY GIGABIT SWITCH - WAS £17.48!
£15.94
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Gigabit ports allow you to connect up to five devices for fast file transfers and smooth media streaming
  • Energy Efficient Ethernet compliance reduces energy consumption without sacrificing performance while cutting down on your power bill
  • Economical yet innovative design runs cool and quiet, making for an unobtrusive addition to the workplace
  • Type: Gigabit Ethernet
  • Ports: 5
  • Data Transfer Rate: 1Gbps
  • Managed: No
  • POE: No
Product codes
Documents
This desktop switch offers an inexpensive alternative to fibre optics for the SOHO and small and medium business (SMB). Increasing network loads can be handled with the increased bandwidth of Gigabit Ethernet.
Gigabit connectivity without fibre
The switch provides 5 Gigabit ports in the familiar Ethernet format, so it works seamlessly with existing network cables (CAT5 or higher). Up to 2000 Mbps can be achieved in full-duplex mode, giving workstations bottleneck-free access to server data.
Plug-and-Play installation
All there is to do is plug the cables into the switch. All ports support both straight-through and crossover cable types, eliminating the need for an uplink port. And with 10/100/1000 Mbps auto-sensing, no configuration is required.
Think Green
By sensing whether attached devices are ON or OFF and estimating the cable length, the switch is able to adjust its power consumption, for a total saving of up to 27%*.
*Figure based on a scenario assuming that PCs are used for 10 hours a day, powered off 14 hours a day and connected to the switch using 20m cables.
  • Power-saving feature, up to 27%* less power consumption (dlink green version only)
  • 5 Gigabit Ethernet ports
  • Plug-and-play installation
  • Desktop size, no fan
Product Description D-Link DGS 1005D - switch - 5 ports
Device Type Switch - 5 ports
Subtype Gigabit Ethernet
Ports 5 x 10/100/1000
MAC Address Table Size 8K entries
Features Flow control, full duplex capability, Layer 2 switching, auto-sensing per device, auto-negotiation, packet filtering
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x
Dimensions (WxDxH) 19.3 cm x 11.9 cm x 3.2 cm
Resources
The following resources are available for the D-Link 5 Port 10/100/1000 Green Ethernet Gigabit Desktop Switch
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link 5 Port 10/100/1...
£15.94
