D-Link 5-Port Gigabit Smart Managed Switch
£26.89
Delivery:
Key features
  • Auto surveillance VLAN and bandwidth control
  • D-Link green/power saving performance
  • Easy to deploy
  • Easy troubleshooting/security
Product codes
D-Link's DGS-1100 Series EasySmart Switches provide an affordable solution for SOHOs, small/medium-sized businesses, as well as enterprise deployments, such as in branch offices that require simple network management. The DGS-1100 Series consists of 5, 8, 16, and 24 10/100/1000 Mbps port models. The 5 and 8 port models come in a compact desktop enclosure, while the 16 and 24 port models come in a compact 11" desktop/rackmount enclosure. Two versions of the 8-port model are available - with and without Power-over-Ethernet (PoE) support. Compliant with IEEE802.3az Energy Efficient Ethernet, these switches consume less power during idle periods. They also implement D-Link Green features that detect link status and cable length and adjust power usage accordingly. Switch management can be performed through a web management interface or through the SmartConsole Utility. The DGS-1100 Series also supports Layer 2 features such as IGMP Snooping to optimize performance for multicast applications. A fanless design allows for quieter operation and provides a longer product life.
Product Description D-Link Smart Managed Switch DGS-1100-05 - switch - 5 ports - smart
Device Type Switch - 5 ports - smart
Subtype Gigabit Ethernet
Ports 5 x 10/100/1000
Performance Switching capacity: 10 Gbps , Forwarding performance: 7.44 Mpps
Capacity VLAN groups: 32 , Virtual interfaces (VLANs): 4094
MAC Address Table Size 8K entries
Jumbo Frame Support 9216 bytes
Remote Management Protocol HTTP
Features Flow control, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, Unicast Storm Control, Quality of Service (QoS), Cable Diagnostics Function, bandwidth control, D-Link Green Technology, fanless, DHCP client, Energy Efficient Ethernet, 1Mbit packet buffer
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 14.1 cm x 8.5 cm x 2.8 cm
Weight 320 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link 5-Port Gigabit...
£26.89
