D-Link 589W Redundant Power Supply
£863.68
Delivery:
Key features
  • Connect to D-Link Ethernet and Gigabit switches
  • Provide backup power for switch's built-in power supply
  • Can be installed as stand-alone power supply units or mounted in 19-inch multi-slot chassis
  • Hot swappable when installed in chassis
  • Solid metal case housing
  • LED status indicators
  • Over-current protection
  • Up to 589 watts output power and supports 1+1 power capability
Product codes
The DPS-700 redundant power supply (RPS) is designed to conform to the wattage requirements of D-Link's Ethernet and Gigabit switches. It is external RPS units enclosed in solid metal cases with sockets to AC or DC power sources on one end, and connect to a switch's internal power supply on the other end. It provides a low-cost, simple solution to the problem of an inadvertent failure of the internal power-supply of an Ethernet switch, which can result in the shutdown of that switch, the devices attached to its ports, or an entire network. Supporting full output power for the switch, these redundant power supplies can maximize the power availability of the switching device.
D-Link DPS-700 - power supply - redundant - 589 Watt
Power supply - redundant - rack-mountable
Rack Size
1U
3.7 kg
Input Voltage
AC 90-264 V
Power Capacity
589 Watt
19.5 cm x 19.6 cm x 5 cm
xStack DGS-3120-24PC, DGS-3120-48PC
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link 589W Redundant...
£863.68
