D-Link 7-Port USB 2.0 Hub
£26.79
27 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Sleek, stylish design
  • Can work without external power or with the included power supply to provide power to connected USB devices
  • Fast-Charge mode to recharge mobile devices like an iPad quickly and effectively
  • Windows app available to synchronise and charge your iPad at the same time
  • Backward compatible with USB 1.1 standard
  • Compatible with Windows, Mac OS and Linux – no drivers needed
  • Type: USB Hub
  • Interface: USB 2.0
  • Speed: 480Mbps
  • Ports: 7
  • Form Factor: External
Product codes
The DUB-H7 is a 7-port Universal Serial Bus USB 2.0 hub that allows you to connect up to 7 USB 2.0 peripherals and devices to your USB 2.0 ready PC or iMac. Providing an out of the box industry standard bus, this pocket-sized device expands your PC and Mac by adding 7 USB 2.0 ports to your system.
A single Type B upstream port is provided to connect to the host computer, or another USB hub. Configured directly by the operating system, the DUB-H7 operates seamlessly with both Microsoft's OpenHCI, Intel's Universal HCI and USB 2.0 new generation specification EHCI.
As a standard USB hub, it buffers USB data from any attached peripherals or devices in compliance with USB specification versions 1.1 and 2.0 to provide an invisible extension of the USB bus. Supporting both low-speed 1.5Mbps devices, full-speed 12Mbps devices and high-speed 480Mbps, each port creates a bridge between the peripheral and host computer.
Product Description D-Link DUB H7 - hub - 7 ports
Device Type Hub - 7 ports
Subtype USB
Ports 7 x USB 2.0
Compliant Standards USB 1.1, USB 2.0
Dimensions (WxDxH) 6.3 cm x 10.4 cm x 2.9 cm
System Requirements Apple MacOS 8.6, Apple MacOS X 10.1, Microsoft Windows 98SE/2000/ME/XP
Localisation United Kingdom, Ireland
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£26.79
