D-Link 8-port 10/100 Desktop Switch
£14.32
35 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Plug and Play operation
  • 8 Fast Ethernet ports
  • Non-blocking architecture: simultaneous full speed on all ports
  • Quality of Service (QoS) queues for traffic prioritisation
  • Solidly built with metal housing, ideal for industrial and hazardous environments
  • D-Link Green technology, saves energy and increases the product's lifespan
  • Type: Fast Ethernet
  • Ports: 8
  • Data Transfer Rate: 100Mbps
  • Managed: No
  • POE: No
Product codes
D-Link's DES-105 and DES-108 Fast Ethernet switches provide a cost-effective way for small to medium sized businesses to create a small network and connect computers, wireless Access Points, IP cameras, network printers and other Ethernet devices quickly and easily without complicated configurations. These switches come with 5 or 8 Fast Ethernet ports with an auto-sensing function to detect the maximum speed of the connected devices, allowing you to run your network with the best possible performance. Their fanless design and solid metal housing makes them completely silent so they are ideal for offices, libraries or meeting rooms, and for industrial and hazardous environments like factories and warehouses.
The DES-105 and DES-108 are designed with durability and performance in mind. Their sturdy metal housing will protect them against accidental harm, while helping to dissipate heat and to reduce stress on internal components. The visible LEDs allow for an easy reading of each port status, helping to troubleshoot connectivity problems. For a convenient placement, these switches come with a wall mounting kit and a slot for a Kensington security lock to protect them from theft.
Despite being unmanaged, Plug and Play switches, the DES-105 and DES-108 are able to classify network traffic by assessing the 802.1p field in the Ethernet frames, and forward them out of its ports depending on their priority. This allows for a smooth integration of video, voice and data traffic without delays or loss of quality.
The DES-105 and DES108 are part of D-Link Green, D-Link's eco-friendly technology, providing energy savings, reduced power consumption, and a longer product lifespan without sacrificing operational performance or functionality. These switches implement the 802.3az Energy Efficient Ethernet (EEE) standard, which can save a substantial amount of energy by detecting the port status, putting them in low-power, stand-by mode when no network traffic is detected. This helps businesses to save money by reducing their electricity bills with no compromise on performance.
Product Description D-Link DES 108 - switch - 8 ports
Device Type Switch - 8 ports
Subtype Fast Ethernet
Ports 8 x 10/100
Features Auto-negotiation, auto-uplink (auto MDI/MDI-X)
Compliant Standards IEEE 802.3x
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link 8-port 10/100 D...
£14.32
