D-Link 8-PORT 10/100 SMART POE SWITCH
Key features
  • Intuitive Web GUI
  • VLAN support for traffic segmentation
  • AutoVoice and AutoSurveillance VLAN for seamless integration with IP telephony and IP surveillance systems
  • QoS (Quality of Service) and bandwidth control to ensure smooth operation
  • Cable diagnostics function to help troubleshoot wiring problems
  • Fanless design: completely silent
Product codes
The DES-1210-08P is a PoE switch in the Fast Ethernet Smart series. Equipped with 8 Fast Ethernet ports, this switch integrates the features of the Smart series with PoE functionality. With an easy to use web interface and eco-friendly design, the DES-1210-08P helps customers to quickly and easily deploy their networks, saving energy and money.
The DES-1210-08P is the ideal solution as an advanced edge switch for SMB and enterprise networks. The Asymmetric VLAN support will provide access to shared resources such as servers or the Internet, without complicated VLAN configurations. Additionally, the innovative AutoVoice and AutoSurveillance VLAN features allow for easy integration of 3rd party IP phones and network cameras, placing traffic from these devices in separate VLANs.
The DES-1210-08P complies with the 802.3af PoE standard. This gives you extra flexibility at deploying appliances such as wireless Access Points, IP cameras and VoIP phones in your network, even in mix-vendor environments. For added flexibility and power-saving, the DES-1210-08P integrates the new Time-Based PoE feature, which turns off the power when it is not needed, for example, at nights or during the weekends. This means that PoE-powered devices which otherwise would be always on, can be switched off centrally, saving power and money.
Product Description D-Link DES 1210 - switch - 8 ports - Managed
Device Type Switch - 8 ports - Managed
Subtype Fast Ethernet
Ports 8 x 10/100 (PoE)
Power Over Ethernet (PoE) PoE
Performance Switching capacity: 1.6 Gbps , Forwarding performance (64-byte packet size): 1.19 Mpps
MAC Address Table Size 8K entries
Remote Management Protocol SNMP 1, SNMP 2, Telnet, SNMP 3, CLI
Features Flow control, Layer 2 switching, DHCP support, auto-negotiation, BOOTP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, port mirroring, store and forward, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, Access Control List (ACL) support, Quality of Service (QoS), Cable Diagnostics Function, bandwidth control
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 19 cm x 12 cm x 3.8 cm
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
