D-Link 802.11 wireless Fast Ethernet LAN PoE Port
£53.07
17 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Extend your network and enjoy wireless speeds of up to 300 Mbps , perfect for everyday business applications
  • Maintain a highly secure network with a range of features including WPA/WPA2, Wireless LAN segmentation and VLAN support
  • Configure to use as an access point, a wireless distribution system (WDS) with access point, a WDS bridge or a wireless client
  • Type: Radio access point
  • Connectivity: Wireless
  • Protocol: IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
  • Compatibility: Mac, PC, Unix
  • Stock Status: In Stock, Used Stock
Product codes
The DAP-2230 Wireless N PoE Access Point allows businesses to create a secure and manageable wireless network. Multiple operational modes, network management tools and security features gives network administrators more flexible deployment options. The DAP-2230 can be ceiling mounted, wall mounted or placed on a desktop to meet any wireless demands.
Product Description D-Link DAP-2230 Wireless N PoE Access Point - radio access point
Device Type Radio access point
Form Factor External
Data Link Protocol IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band 2.4 GHz
Included Accessories Wall mounting kit
Power Over Ethernet (PoE) Supported PoE
Dimensions (WxDxH) 12.9 cm x 12.9 cm x 2.9 cm
Weight 101.4 g
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been opened but is in excellent condition
Ref: C554 040817
£33.10
product
Ref: C554 040817
Accessories
Packaging
Functional
Software
Manuals
£33.10
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link 802.11 wireless...
£53.07
