D-Link AC1200 GB Router
£44.26
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Stream HD video or make Internet voice calls across your home, using the fastest wired and wireless connectivity options available today
  • Access your network via two concurrent wireless bands for seamless performance no matter what you are doing
  • Set up the DIR-842 in no time either with the web-based setup wizard or the free QRS App, and create a secure wireless connection easily using Wi-Fi Protected Setup (WPS)
  • Type: Wireless router
  • Standards: Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11a + 4 more
  • Stock Status: In Stock
Product codes
The DIR-842 Wireless AC1200 Dual Band Gigabit Router combines the latest high-speed 802.11ac dual-band Wi-Fi with Gigabit Ethernet ports to provide a seamless networking experience. The DIR-842's advanced security features keep data safe from unwanted network intruders, whilst the increased range and reliability of Wireless AC technology allows you to stay connected even under heavy network utilization or in rooms that have bad wireless signal.
Product Description D-Link DIR-842 - wireless router - 802.11a/b/g/n/ac - desktop
Device Type Wireless router - 4-port switch (integrated)
Enclosure Type Desktop
WAN Ports Qty 1
Data Link Protocol Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band 2.4 GHz / 5 GHz
Network / Transport Protocol PPTP, L2TP, PPPoE, DHCP, DNS, DDNS
Remote Management Protocol HTTP
Features Interrupt status port (ISP), IPv6 support, Wi-Fi Protected Setup (WPS), static IP mode, 2T2R MIMO technology, IPv4 support, dynamic IP mode
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Power AC 120/230 V (50 - 60 Hz)
Dimensions (WxDxH) 18.994 cm x 13.297 cm x 3.81 cm
Weight 288 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
£44.26
