D-Link AC750 Wireless Router
£61.38
Delivery:
Key features
  • Conveniently create a reliable, high-speed Wireless AC network anywhere you have a mobile broadband signal
  • Attach your 4G LTE/3G USB dongle to the router’s USB port to share your high-speed mobile Internet service with family or colleagues
  • Load sharing and fail-safe Internet with concurrent fixed line and mobile Internet support
Product codes
The DWR-118 Wireless AC750 Dual-Band Multi-WAN Router allows you to share superfast 4G LTE/3G mobile Internet simultaneously to your smartphone, tablet, notebook and desktop computer. Universal 4G LTE/3G USB dongle support from any mobile operator, this router is the ideal solution for setting up an Internet connection to share with your colleagues or your family and friends when you are on holiday. Wireless AC allows you to create a fast and secure high speed personal hotspot with wireless speeds of up to 433 Mbps
Simultaneous 4G
LTE/3G mobile Internet and fixed broadband Internet support allows you to combine Internet connections to give you faster Internet speeds. You can also set up fail-safe Internet should either connections fail.
Reliable, Uninterrupted and Faster Internet Connection
Create a load sharing and fail-safe Internet connection with simultaneous 4G LTE/3G mobile Internet and fixed broadband Internet support. A Gigabit Ethernet WAN port allows you to attach a DSL/Cable modem as the primary or backup link, while auto-failover ensures an uninterrupted connection by automatically connecting to your 4G LTE/3G network whenever the WAN link is lost. Load sharing function allows the Internet connections to be combined to give you faster Internet speeds. The built-in QoS management feature also prioritises traffic to ensure that the most important data receives optimum bandwidth.
Incredible Wireless Speeds
The DWR-118 supports the latest, high-speed 4G LTE mobile broadband technology, allowing you to achieve blazing fast mobile broadband speeds. In addition to this, the Wireless AC750 Dual-Band Multi-WAN Router’s AC technology means that you can connect wireless clients to the router at up to 433 Mbps, with the enhanced range and reliability of the dual-band 802.11ac wireless standard.
Advanced Network Security
The DWR-118 ensures a secure Wi-Fi network through the use of WPA/WPA2 wireless encryption. Simply press the WPS button to quickly establish a secure connection to new devices. The DWR-118 also utilises dual-active firewalls (SPI and NAT) to prevent potential attacks and intrusions from across the Internet.
Simple to Install and Use
The Wireless AC750 Dual-Band Multi-WAN Router can be installed quickly and easily almost anywhere. The intuitive setup wizard will get you set up and connected in no time. This router is great for situations where an impromptu wireless network is required, or where conventional wired network access is unavailable. The DWR-118 can even be installed on buses, trains, or boats, allowing passengers to access the Internet while commuting
D-Link DWR-118 - wireless router - WWAN - 802.11b/g/n/ac - desktop
Wireless router - wireless cellular modem - 4-port switch (integrated)
Enclosure Type
Desktop
Cellular Protocol
CDMA, UMTS, HSDPA, HSUPA, HSPA+, LTE
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Network / Transport Protocol
PPTP, L2TP, IPSec
NAT support, Stateful Packet Inspection (SPI), MAC address filtering, VPN passthrough, URL filtering, Quality of Service (QoS), Wi-Fi Protected Setup (WPS)
IEEE 802.3, IEEE 802.3u, Wi-Fi CERTIFIED
14.85 cm x 11.35 cm x 2.5 cm
350 g
Customer reviews
Accessories
Network Adaptors
Other bundles
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link AC750 Wireless...
£61.38
