D-Link AirPlus G DWL-G700AP Access Point
Key features
  • 5 GHz directional high-gain antennas deliver extended coverage via WDS bridging connections and 2.4 GHz omnidirectional antennas provide local Wi-Fi access
  • Can be used as a standalone wireless access point as well as clustered and managed centrally via a D-Link Wireless Controller or Unified Switch
  • An all-in-one plastic enclosure with pole-mount design simplifies outdoor deployment and a remote reset button via a PoE injector for hassle-free reboots
Product codes
The DWL-6700AP has a sleek, weatherproof housing design with an embedded antenna so it can be easily mounted onto a pole or wall. Its ability to operate between -30°C to 50°C, protecting against exposure to heat, cold or rain makes this an ideal outdoor wireless access point.
Product Description D-Link DWL-6700AP - radio access point
Device Type Radio access point
Form Factor External
Data Link Protocol IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band 2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported PoE
Dimensions (WxDxH) 28 cm x 11.5 cm x 5 cm
Weight 495 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link AirPlus G DWL-G...
