The DAP-2360 is a versatile, high power design access point designed to reduce dead spots and increase capacity. With a white plenum-rated metal chassis, the DAP-2360 allows the access point to blend into ceilings or walls whilst adhering to strict fire codes for placement in air passageways.
Product Description | D-Link AirPremier N PoE Access Point with Plenum-rated Chassis DAP-2360 - radio access point | Device Type | Radio access point | Form Factor | External - indoor | Data Link Protocol | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n | Frequency Band | 2.4 GHz | Power Over Ethernet (PoE) Supported | PoE | Dimensions (WxDxH) | 16.6 cm x 18.8 cm x 3.7 cm | Weight | 0.77 kg | Manufacturer Warranty | Limited lifetime warranty |
General | |
Ruggedized Design | Indoor |
Width | 16.6 cm |
Depth | 18.8 cm |
Height | 3.7 cm |
Weight | 0.77 kg |
Networking | |
Form Factor | External |
Connectivity Technology | Wireless |
Data Transfer Rate | 300 Mbps |
Remote Management Protocol | SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH |
Status Indicators | Power, WLAN |
Features | VLAN support, MAC address filtering, Wireless Distribution System (WDS) support, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Multiple SSID support, Network Access Protection (NAP) |
Encryption Algorithm | 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise |
Authentication Method | Radio Service Set ID (SSID) |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n |
Aerial | |
Antenna | External detachable |
Antenna Qty | 2 |
Gain Level | 5 dBi |
Expansion / Connectivity | |
Interfaces | 1 x 1000Base-T - RJ-45 |
Miscellaneous | |
Compliant Standards | FCC Class B certified, IC, UL 2043 |
Power | |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
