D-Link AirPremier N PoE Access Point with Plenum-rated Chassi...
D-Link AirPremier N PoE Access Point with Plenum-rated Chassis DAP-2360
£109.32
Delivery:
Standard: 1-3 working days
Key features
  • Increase your network capacity with fast 802.11n wireless, captive portal user authentication, and support for up to 8 VLANs to help segment users
  • Discreet design blends into any office environment, and the durable housing can be placed out of the way in air spaces
  • Experience faster, more reliable connections from farther away with improved wireless speed, range and coverage
  • Type: Radio access point
  • Connectivity: Wireless
  • Speed: 300Mbps
  • Protocol: IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
  • Compatibility: PC
Product codes
The DAP-2360 is a versatile, high power design access point designed to reduce dead spots and increase capacity. With a white plenum-rated metal chassis, the DAP-2360 allows the access point to blend into ceilings or walls whilst adhering to strict fire codes for placement in air passageways.
Product Description D-Link AirPremier N PoE Access Point with Plenum-rated Chassis DAP-2360 - radio access point
Device Type Radio access point
Form Factor External - indoor
Data Link Protocol IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band 2.4 GHz
Power Over Ethernet (PoE) Supported PoE
Dimensions (WxDxH) 16.6 cm x 18.8 cm x 3.7 cm
Weight 0.77 kg
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link AirPremier N Po...
£109.32
