D-Link D-Link Wireless N PoE Outdoor Access Point
Key features
  • Configure to use as an access point, a wireless distribution System (WDS) with access point, a WDS bridge or a wireless client
  • Includes industry standard wireless encryption along with support for multiple SSIDs and VLANs, allowing for complete control over network access
  • IP55 weatherproof housing and weathershield2 makes the DAP-3320 ideal for demanding networking environments
Product codes
The DAP-3320 Wireless PoE Outdoor Access point is the ideal solution for expanding the coverage and signal strength of any wireless network. Built to withstand outdoor environments, the DAP-3320 also excels in connecting separate networks that cannot be joined using physical wiring.
Product Description D-Link DAP-3320 - radio access point
Device Type Radio access point
Form Factor External - outdoor
Data Link Protocol IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band 2.4 GHz
Power Over Ethernet (PoE) Supported PoE
Dimensions (WxDxH) 3.586 cm x 10.543 cm x 22.86 cm
Weight 370.4 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link D-Link Wireless...
