D-Link DBA-1210P AC1300 Wave2 Nuclias Access Point
£156.94
Delivery:
Standard: 1-3 working days
Key features
  • Zero-touch provisioning
  • Unlimited scalability with no limitation on amount of supported APs
  • Centralized cloud-based management
  • Intuitive web and app-based interface
  • IEEE 802.11ac Wave 2 Wireless
  • 2 x 2 MIMO with two spatial streams
  • Up to 1200 Mbps
  • Gigabit PoE Ethernet LAN port
  • Supports band steering
  • Supports load balancing
  • IEEE 802.3af Power over Ethernet (PoE)
  • Supports up to 8 virtual access points
  • WPA/WPA2 - Enterprise/Personal
  • Supports RADIUS client and Cipher negotiation
  • MAC address filtering
  • Network Access Protection (NAP)
  • ARP spoofing prevention
  • WLAN partition
  • Type: Radio access point
  • Connectivity: Wireless
  • Speed: 1200Mbps
  • Protocol: IEEE 802.11a, IEEE 802.11ac Wave 2, IEEE 802.11b, IEEE 802.11g + 1 more
  • Stock Status: In Stock
Product codes
The DBA-1210P Business Cloud Wave 2 access point is designed specifically for enterprise environments. With new generation 802.11ac dual-band concurrent 2.4 GHz and 5.0 GHz radios, the DBA-1210P offers high combined data rates to wireless clients allowing for lightning-fast access to bandwidth intensive applications such as data, voice, and video. The DBA-1210P is meant to be deployed as a pre-managed, zero configuration access point controlled through the D-Link Business Cloud, allowing network administrators to spend more time on providing reliable connectivity and services and less time managing devices.
Product Description D-Link Business Cloud Wave 2 DBA-1210P - radio access point
Device Type Radio access point
Form Factor External
Data Link Protocol IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Frequency Band 2.4 GHz, 5 GHz
Capacity Virtual access points: 8
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 17 cm x 17 cm x 2.8 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link DBA-1210P AC130...
£156.94
