D-Link DCS-935L mydlink Home Monitor HD
Key features
  • See all the details with high definition 720p colour images with sound. Access live video feeds of your home on smartphone or tablet using the mydlink Home app
  • Infrared illuminators provide exceptional lowlight and night-time vision, enabling the monitor to see up to 5 metres in complete darkness
  • Never miss an important moment, with the ability to be alerted by either sound or motion detection
Product codes
mydlink™ Home app-enabled.
Use the free mydlink™ Home app to view what your Monitor HD sees, using your tablet or smartphone to control it wherever you are in the world.
Wireless connectivity.
Connect the Monitor HD to your Wireless home network, easily and conveniently, using one-button setup.
Motion detection with night vision.
Never miss a thing with the ability to be notified when motion is detected, and night vision ensures clear images even in low-light conditions, so you can always see what the Monitor HD sees.
HD Clarity
Easy to Setup
Simply press a button to securely connect to your home Wi-Fi network with Wi-Fi Protected Setup. No additional control hub needed.
High Definition
Monitor your home in crystal clear HD 720p - See everything in detail, even when zoomed in.
See in the Dark
Built-in night vision function allows you to see up to 5 metres even in complete darkness.
Motion & Sound Detection
Alerts you with push notification whenever motion or sound is detected.
View From Anywhere
View securely over the Internet through your smartphone or tablet. Works with iOS and Android smartphone and tablet* through the free mydlink™ Home app.
* mydlink™ Home app is available for iPod, iPhone and iPad devices using iOS version 6.0 or later, and Android devices using Android version 4.0 or later.
Product Description mydlink Home Monitor HD - network surveillance camera
Device Type Network surveillance camera - fixed
Audio Yes: built-in microphone
Dimensions (WxDxH) 5.8 cm x 8.45 cm x 12.49 cm
Weight 160 g
Connectivity Technology Wireless
Camera Colour - Day&Night
Max Resolution 1280 x 720
Optical Sensor Type CMOS - 1/4"
Minimum Illumination 0 lux - IR - F2.4
Focal Length 2.38 mm
Focus Adjustment (min distance 434 mm)
Lens Iris F/2.4
Interfaces IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Voltage DC 5 V
Features Motion sensor, date/time stamp, sharpness control, progressive scanning, saturation control, brightness control, contrast control, infrared cut filter, hue control, Wi-Fi Protected Setup (WPS), text stamp
Environmental Parameters (operating) 0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link DCS-935L mydlin...
