D-Link DEM-311GT 1-Port Mini GBIC SX Multi Mode Fiber Transce...
D-Link DEM-311GT 1-Port Mini GBIC SX Multi Mode Fiber Transceiver
£51.00
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 1000Base-SX port (IEEE 802.3z standard)
  • Fibre type: 50 um or 62.5 um multi-mode, up to 550 m
  • Wave length: 850 nm
  • Type: Transceiver
  • Stock Status: In Stock
Product codes
This transceiver uses the industry-standard Small form Pluggable (SFP) package. It slides into the mini-GBIC slot of the Gigabit device. Like all D-Link mini-GBIC transceivers, it is hot-swappable: you can remove or replace the transceiver with the system powered on, which allows modules to be added or swapped without interrupting the network.
Product Description D-Link DEM 311GT - SFP (mini-GBIC) transceiver module - GigE
Device Type SFP (mini-GBIC) transceiver module - LC multi-mode
Form Factor Plug-in module
Cabling Type 1000Base-SX
Data Transfer Rate 1 Gbps
Optical Wave Length 850 nm
Data Link Protocol GigE
Max Transfer Distance 550 m
Designed For D-Link Data Center 10; DES 12XX, 30XX; DGS 12XX, 3100, 32XX, 33XX, 3630; DWS 3024; DXS 1100, 1210, 3400, 3600; L2+ Gigabit Wireless Switch; Web Smart DES-1228, 1252, DGS-1216, 1224, 1248, DXS-1210-12; xStack DES-3526, 3528, 3552, 3828, 3852, DGS-3426, 3427, 3450, 3612, 3627, 3650, DXS-3326, 3350
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link DEM-311GT 1-Por...
£51.00
