We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The DES-1005D 5-Port Fast Ethernet Unmanaged Desktop Switch is a five port fast Ethernet switch that allows you to quickly set up a wired network.
Connect the DES-1005D to multiple computers together to share files and folders, or connect it to a router to share an Internet connection.
No configuration is required, making this switch completely plug-and-play.
Auto-Sensing 10/100 Ports
The DES-1005D 5-Port Fast Ethernet Unmanaged Desktop Switch uses auto-sensing 10/100 Mbps ports, allowing a small workgroup to flexibly connect to Ethernet and Fast Ethernet devices to create an integrated network. These ports detect the network speed and auto-negotiate between 10BASE-T and 100BASE-TX, as well as between full and half-duplex, allowing you to get the maximum speed possible for each device connected to your network.
Auto MDI/MDIX Crossover
All ports support automatic MDI/MDIX crossover, eliminating the need for crossover cables or uplink ports. Each port can be plugged directly to a server, hub, router, or switch using regular straight-through twisted-pair Ethernet cables.
Flow Control for Secure Transmission
802.3x flow control on each port minimizes dropped packets when the port’s receiving buffer is full. This gives you a more reliable connection for all of your connected devices.
Product Description | D-Link DES 1005D - switch - 5 ports - unmanaged | Device Type | Switch - 5 ports - unmanaged | Subtype | Fast Ethernet | Ports | 5 x 10/100 | MAC Address Table Size | 2K entries | Features | Flow control, auto-sensing per device, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3x | Dimensions (WxDxH) | 14.2 cm x 10.8 cm x 3.2 cm |
General | |
Enclosure Type | Desktop |
Status Indicators | Collision status, port transmission speed, port duplex mode, power, link/activity |
Expansion / Connectivity | |
Interfaces | 5 x 100Base-TX RJ-45 |
Power | |
Power Device | External power adapter |
Power Consumption Operational | 3.6 Watt |
Miscellaneous | |
Compliant Standards | Plug and Play, FCC Class B certified, VCCI Class B ITE |
Dimensions & Weight | |
Width | 14.2 cm |
Depth | 10.8 cm |
Height | 3.2 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 10 - 90% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
