The D-Link DES-1018P/DES-1018MP 18-Port Fast Ethernet PoE Switches with 2 Gigabit Uplink Ports enables users to easily connect and supply power to PoE-capable devices such as wireless access points (APs), network cameras and IP phones. They can also connect other Ethernet devices like computers, printers and network attached storage (NAS) to fit into any type of network application.
Product Description | D-Link DES 1018MP - switch - 18 ports - unmanaged | Device Type | Switch - 18 ports - unmanaged | Enclosure Type | 1U | Subtype | Fast Ethernet | Ports | 16 x 10/100 (PoE) + 2 x combo Gigabit SFP | Power Over Ethernet (PoE) | PoE | PoE Budget | 80 W | Performance | Switching capacity: 7.2 Gbps , Forwarding performance (64-byte packet size): 5.36 Mpps | MAC Address Table Size | 8K entries | Features | Flow control, power over Ethernet (PoE), auto-uplink (auto MDI/MDI-X), store and forward, Energy Efficient Ethernet | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3af, IEEE 802.3x, IEEE 802.3az | Power | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) | 28 cm x 21 cm x 4.4 cm | Weight | 1.78 kg |
General | |
Enclosure Type | Desktop 1U |
PoE Budget | 80 W |
Status Indicators | Port transmission speed, power, link OK, link/activity |
Expansion / Connectivity | |
Interfaces | 16 x 100Base-TX RJ-45 PoE - 15.4 W , 2 x 1000Base-T RJ-45 , 2 x 1000Base-X SFP |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 102.6 Watt |
Miscellaneous | |
MTBF | 395,864 hours |
Compliant Standards | FCC Class A certified, cUL, CB, CCC, RoHS, LVD |
Dimensions & Weight | |
Width | 28 cm |
Depth | 21 cm |
Height | 4.4 cm |
Weight | 1.78 kg |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 0 - 95% (non-condensing) |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
