D-Link DGS-1100 (24-Port) Gigabit Smart Switch
£219.86
12 in stock
Delivery:
Standard: 1-3 working days
Key features
  • High-speed ports provide Gigabit Ethernet technology while remaining backward compatible for connections to older computers and equipment
  • Innovative D-Link Green features help to conserve energy without affecting performance so you can reduce operating costs and protect the environment
  • Powerful switch management functions can be performed through a web management interface or through the D-Link Network Assistant Utility
  • Type: Gigabit Ethernet
  • Ports: 24
  • Data Transfer Rate: 1Gbps
  • Managed: Yes
  • POE: PoE+
Product codes
D-Link's DGS-1100 Series provide an affordable solution for SOHOs and Small and Medium Businesses as well as enterprise deployment, such as in branch offices and meeting rooms that require simple network management. Most models comes in a compact desktop-sized metal case and features a wide selection of Gigabit port configurations with optional Gigabit fiber uplink ports. There are 4 switches in the series supporting Power-over-Ethernet with 2 of the switches in the offering high-power-budget PoE for businesses looking to power VoIP phones, wireless access points or network cameras.
Product Description D-Link DGS 1100-24P - switch - 24 ports - Managed - rack-mountable
Device Type Switch - 24 ports - Managed
Enclosure Type Rack-mountable 1U
Subtype Gigabit Ethernet
Ports 12 x 10/100/1000 (PoE+) + 12 x 10/100/1000
Power Over Ethernet (PoE) PoE+
PoE Budget 100 W
Performance Switching capacity: 48 Gbps , Forwarding performance: 35.71 Mpps
MAC Address Table Size 8K entries
Jumbo Frame Support 9216 bytes
Remote Management Protocol HTTP
Features Flow control, full duplex capability, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, DoS attack prevention, port mirroring, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Quality of Service (QoS), Cable Diagnostics Function, bandwidth control, D-Link Green Technology, LLDP support, DHCP client, Energy Efficient Ethernet, 512KB packet buffer
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3at, IEEE 802.3az
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 28 cm x 23 cm x 4.4 cm
Weight 2.15 kg
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link DGS-1100 (24-Po...
£219.86
