D-Link DGS-1210-52P (52-Port) Gigabit Smart PoE Switch 4 SFP...
D-Link DGS-1210-52P (52-Port) Gigabit Smart PoE Switch 4 SFP Ports
Key features
  • D-Link Green technology conserves energy by powering down unused ports, saving you money while reducing your carbon footprint
  • Advanced management functions make for a truly versatile switch that integrates performance and scalability
  • Fully IPv6 compatible and ready for enterprise deployment, giving you a head start on the next Internet standards evolution
Product codes
The DGS-1210-10/10P/20/28 features a fanless design that allows for quieter operation and helps to extend the device's lifetime. While the DGS-1210-28P/52/52P feature a smart fan design that powers on after the switch reaches a certain temperature, saving energy and cutting costs without sacrificing performance.
Product Description D-Link Smart+ DGS-1210-52P - switch - 52 ports - Managed - rack-mountable
Device Type Switch - 52 ports - Managed
Enclosure Type Rack-mountable 1U
Subtype Gigabit Ethernet
Ports 8 x 10/100/1000 (PoE+) + 16 x 10/100/1000 (PoE) + 24 x 10/100/1000 + 4 x SFP
Power Over Ethernet (PoE) PoE+
PoE Budget 193 W
Performance Switching capacity: 104 Gbps , Forwarding performance (64-byte packet size): 77.4 Mpps
Capacity IGMP groups: 256 , QoS hardware queues per port: 8 , ACL rules: 768 , ARP entries: 64
MAC Address Table Size 16K entries
Jumbo Frame Support 9216 bytes
Remote Management Protocol SNMP 1, RMON 1, Telnet, SNMP 3, SNMP 2c, HTTP, CLI
Features Flow control, full duplex capability, auto-negotiation, BOOTP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, port mirroring, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, DHCP snooping, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, Dynamic ARP Inspection (DAI), Safeguard Engine, Cable Diagnostics Function, bandwidth control, D-Link Green Technology, Port Security, IP-MAC binding, SNMP trap, DHCP client, Strict Priority Queuing (SPQ), Multicast filtering function, Class of Service (CoS), 802.1x authentication, Type of Service (ToS), DiffServ Code Point (DSCP) support, 3MB packet buffer
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 44 cm x 43 cm x 4.4 cm
Weight 5.66 kg
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link DGS-1210-52P (5...
