D-Link DGS-1510-52X 52-Port Gigabit Managed Smart Switch SFP+
£552.04
Delivery:
Standard: 1-3 working days
Key features
  • 10G physical stacking and/or uplink eliminates the bottleneck of stacking backbone servers, and storage accesses
  • Intuitive graphical Web UI complete with 10 languages for SMB; Comprehensive Command Line Interface (CLI) and SNMP for Out-of-band console management
  • Wired speed inter-VLAN routing helps by reducing the pressure of routers and backbone networks, improving the overall network efficiency
  • Type: Gigabit Ethernet
  • Ports: 52
  • Data Transfer Rate: 1Gbps
  • Managed: Yes
  • POE: No
Product codes
The DGS-1510 series is the next generation of smart managed switch. It contains 16, 24 or 48 10/100/1000 Mbps ports plus 2 Gigabit SFP ports and 2 10G SFP+ ports, 24/48 10/100/1000 Mbps ports plus 4 10G SFP+ ports, as well as one 24 10/100/1000 Mbps PoE plus 2 Gigabit SFP ports and 2 10G ports smart managed switch. With it's 10G SFP+ ports, the DGS-1510 series is ideal for deployments in the SME/SMB core with its 10G uplinks connecting with servers equipped with 10G port connectivity. For medium to large scale enterprise deployment, it can serve as a good interconnection between the core switch and edge switch.
Product Description D-Link SmartPro DGS-1510-52X - switch - 52 ports - Managed - rack-mountable
Device Type Switch - 52 ports - L3 - Managed - stackable
Enclosure Type Rack-mountable 1U
Subtype Gigabit Ethernet
Ports 48 x 10/100/1000 + 4 x 10 Gigabit SFP+
Performance Switching capacity: 176 Gbps , Forwarding performance (64-byte packet size): 130.95 Mpps , Stacking bandwidth: 20 Gbps
Capacity ARP entries: 256 , IPv6 routing table entries: 32 , IPv4 routing table entries: 64 , ACL entries: 256 , ACL rules: 768 , IGMP groups: 512 , Layer 2 multicast addresses: 128
MAC Address Table Size 16000 entries
Jumbo Frame Support 9000 bytes
Routing Protocol Static IPv4 routing, static IPv6 routing
Remote Management Protocol SNMP 1, RMON 1, Telnet, SNMP 3, SNMP 2c, HTTP, TFTP, CLI
Features Flow control, full duplex capability, auto-negotiation, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DoS attack prevention, port mirroring, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, DHCP server, MLD snooping, Dynamic ARP Inspection (DAI), Safeguard Engine, Cable Diagnostics Function, bandwidth control, D-Link Green Technology, Deficit Weighted Round Robin (DWRR), LLDP support, IP-MAC binding, SNMP trap, DHCP client, Energy Efficient Ethernet, Strict Priority Queuing (SPQ), Class of Service (CoS), tagged VLAN, Generic VLAN Registration Protocol (GVRP), D-Link Single IP Management (SIM), DiffServ Code Point (DSCP) support
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.3az
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 44 cm x 25 cm x 4.4 cm
Weight 2.4 kg
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link DGS-1510-52X 52...
£552.04
