We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The DGS-3130 Series switches are Lite Layer 3 Stackable Managed Switches designed to connect end-users in a secure enterprise or metro Ethernet access network. These switches support multicast, and enhanced security, making them an ideal Gigabit access layer solution.
Product Description | D-Link DGS 3130-54S - switch - 54 ports - Managed | Device Type | Switch - 54 ports - L3 Lite - Managed - stackable | Subtype | Gigabit Ethernet | Ports | 48 x SFP + 2 x 10 Gigabit Ethernet + 4 x 10 Gigabit SFP+ | Performance | Switching capacity: 216 Gbps , Forwarding performance (64-byte packet size): 161 Mpps | Capacity | Packet buffer size: 4 MB , Units per virtual stack: up to 32 , IGMP groups: 1024 , Virtual interfaces (VLANs): 4000 , QoS hardware queues: 8 | MAC Address Table Size | 16384 entries | Jumbo Frame Support | 9KB | Routing Protocol | RIP-1, RIP-2, IGMPv2, IGMP, VRRP, IGMPv3, static IPv4 routing, static IPv6 routing, RIPng, MLDv2, MLD | Remote Management Protocol | SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, TFTP, SSH-2, CLI, NTP | Features | Flow control, BOOTP support, IGMP snooping, port mirroring, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), DHCP server, MLD snooping, Cable Diagnostics Function, bandwidth control, LLDP support, DHCP relay, Port Security, DHCP client, Strict Priority (SP), Single IP Management (SIM), Ethernet Ring Protection Switching (ERPS), IGMP filtering, 5 fans, system log, Internet Control Message Protocol (ICMP), Management Information Base (MIB) II, Authentication, Authorization and Accounting (AAA), VLAN Double Tagging (Q-in-Q), Web-based Access Control (WAC), DNS client, proxy ARP, Energy-Efficient Ethernet (EEE), BPDU Filter, Weighted Round Robin (WRR), Head-of-line (HOL) Blocking Prevention, loopback detection, Telnet server, Telnet client, Root Restriction | Compliant Standards | IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1v, IEEE 802.1ab (LLDP), IEEE 802.3az | Power | AC 120/230 V (50/60 Hz) | Power Redundancy | Optional | Dimensions (WxDxH) | 44 cm x 35 cm x 4.4 cm | Weight | 4.52 kg |
General | |
Max Units In A Stack | 12 |
Encryption Algorithm | SSL, SSL 3.0, SSL 2.0 |
Authentication Method | Secure Shell v.2 (SSH2) |
Expansion / Connectivity | |
Interfaces | 48 x 1000Base-X SFP , 2 x 10GBase-T RJ-45 , 4 x 10GBase-X SFP+ , 1 x 10/100/1000 Base-T RJ-45 console , 1 x 10/100/1000 Base-T RJ-45 management , 1 x USB 2.0 Type A |
Power | |
Power Device | Internal power supply - hot-plug |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 131 Watt |
Miscellaneous | |
MTBF | 520,861 hours |
Compliant Standards | FCC Class A certified, BSMI, cUL, CB, CCC, IC, VCCI Class A, RCM |
Software / System Requirements | |
Software Included | Standard Image (SI) Software |
Dimensions & Weight | |
Width | 44 cm |
Depth | 35 cm |
Height | 4.4 cm |
Weight | 4.52 kg |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 10 - 90% |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 90% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
