D-Link DGS-3630-28SC/SI xStack Gigabit L3 Stackable Managed S...
D-Link DGS-3630-28SC/SI xStack Gigabit L3 Stackable Managed Switch
£1,572.56
Delivery:
Notify me
Key features
  • Standard, enhanced, and MPLS images
  • High availability and flexibility
  • Security, performance & availability
  • D-Link Green technology
  • Ports: 28
  • Managed: Yes
Product codes
The DGS-3630 Series Layer 3 Stackable Managed Switch is designed for Small Medium Businesses (SMBs), Small Medium Enterprises (SMEs), enterprises, and ISPs. It delivers high-performance, flexibility, fault tolerance, and advanced software features for maximum return on investment. With Gigabit Ethernet SFP, 10 GbE SFP+, security features, and advanced Quality of Service (QoS), the DGS-3630 Series can act as core, distribution or access layer switches. High port densities, switch stacking, and easy management make the DGS-3630 Series suitable for a variety of applications.
Product Description D-Link DGS 3630-28SC - switch - 28 ports - Managed - rack-mountable
Device Type Switch - 28 ports - L3 - Managed - stackable
Enclosure Type Rack-mountable
Ports 20 x Gigabit SFP + 4 x combo 1000Base-T + 4 x 10 Gigabit SFP+
Performance Switching capacity: 128 Gbps , Forwarding performance: 95.24 Mpps , Stacking bandwidth: 80 Gbps
Capacity IPv4 routing table entries: 16000 , IPv6 routing table entries: 7000 , IPv4 forwarding table entries: 32000 , IPv6 forwarding table entries: 16000 , VLAN groups: 4000 , Dynamic VLAN entries: 4000 , Static ARP entries: 512 , IPv4 routes (static): 512 , IPv6 routes (static): 256 , QoS hardware queues per port: 8 , ACL entries (egress): 4000 , ACL entries (ingress): 1000
MAC Address Table Size 68K entries
Jumbo Frame Support 12KB
Routing Protocol BGP-4, RIP-1, RIP-2, IGMPv2, IGMP, VRRP, OSPFv2, PIM-SM, PIM-DM, IGMPv3, OSPFv3, PIM-SSM, MSDP, static IPv4 routing, static IPv6 routing, policy-based routing (PBR), DVMRPv3, RIPng, MLDv2, MLD, BGP-4+, VRRPv2, Bidirectional Forwarding Detection (BFD), VRRPv3, URPF
Remote Management Protocol SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTPS, TFTP, CLI
Features ARP support, IGMP snooping, DoS attack prevention, packet filtering, port mirroring, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, Dying Gasp support, sFlow, PIM snooping, tunnelling, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), IP Precedence, DHCP server, Virtual Route Forwarding-Lite (VRF-Lite), MLD snooping, Dynamic ARP Inspection (DAI), Safeguard Engine, Cable Diagnostics Function, bandwidth control, LLDP support, Port Security, Remote Switch Port Analyzer (RSPAN), SNMP trap, DHCP client, Energy Efficient Ethernet, Dynamic VLAN Support (GVRP), Strict Priority (SP), Loopback, TFTP client, 4MB packet buffer, 802.1x authentication, Duplicated Address Detection, Two Rate Three Color Marking (TRTCM), Type of Service (ToS), Precision Time Protocol (PTP), DiffServ Code Point (DSCP) support, 2 fans, IGMP filtering, Single Rate Three Color Marking (SRTCM), IP source guard, Head of Line Blocking Prevention, host based access control, Priority-Based Flow Control (PFC), VLAN Trunking Protocol (VTP), Bridge protocol data unit (BPDU), Link Aggregation, Management Information Base (MIB) II, Source-Specific Multicast (SSM), Digital Diagnostics Monitoring (DDM), Network Timing Protocol (NTP), Authentication, Authorization and Accounting (AAA), VLAN Double Tagging (Q-in-Q), Loop Guard, Ethernet Ring Protection Switching (ERPS) v2, VLAN mirroring, MLD filtering, Web-based Access Control (WAC), Switch Resource Management (SRM)
Compliant Standards IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1v, IEEE 802.1ag, IEEE 802.1ab (LLDP), IEEE 802.1AX, IEEE 802.1Qbb
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 44.1 cm x 26 cm x 4.4 cm
Weight 3.79 kg
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£1,572.56
Notify me
