We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The DGS-3630 series Layer 3 stackable managed switches are designed for small to mediumsized businesses, small to medium-sized enterprises, large enterprises, and Internet service providers. They deliver high performance, flexibility, fault tolerance, and advanced software features for maximum return on investment. With Gigabit Ethernet, SFP, 10 GbE SFP+, security features, and advanced Quality of Service (QoS), the DGS-3630 series can act as core, distribution, or access layer switches. High port densities, switch stacking, and easy management make the DGS-3630 series suitable for a variety of applications.
Product Description | D-Link DGS 3630-52PC - switch - 44 ports - Managed - rack-mountable | Device Type | Switch - 44 ports - L3 - Managed - stackable | Enclosure Type | Rack-mountable | Ports | 44 x 10/100/1000 (PoE+) + 4 x combo Gigabit SFP + 4 x 10 Gigabit SFP+ | Power Over Ethernet (PoE) | PoE+ | PoE Budget | 370 W | Performance | Switching capacity: 176 Gbps , Forwarding performance: 130.95 Mpps , Stacking bandwidth: 80 Gbps | Capacity | IPv4 routing table entries: 16000 , IPv6 routing table entries: 7000 , IPv4 forwarding table entries: 32000 , IPv6 forwarding table entries: 16000 , VLAN groups: 4000 , Dynamic VLAN entries: 4000 , Static ARP entries: 512 , IPv4 routes (static): 512 , IPv6 routes (static): 256 , QoS hardware queues per port: 8 , ACL entries (egress): 4000 , ACL entries (ingress): 1000 | MAC Address Table Size | 68K entries | Jumbo Frame Support | 12KB | Routing Protocol | BGP-4, RIP-1, RIP-2, IGMPv2, IGMP, VRRP, OSPFv2, PIM-SM, PIM-DM, IGMPv3, OSPFv3, PIM-SSM, MSDP, static IPv4 routing, static IPv6 routing, policy-based routing (PBR), DVMRPv3, RIPng, MLDv2, MLD, BGP-4+, VRRPv2, Bidirectional Forwarding Detection (BFD), VRRPv3, URPF | Remote Management Protocol | SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTPS, TFTP, CLI | Features | ARP support, IGMP snooping, DoS attack prevention, packet filtering, port mirroring, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, Dying Gasp support, sFlow, PIM snooping, tunnelling, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), IP Precedence, DHCP server, Virtual Route Forwarding-Lite (VRF-Lite), MLD snooping, Dynamic ARP Inspection (DAI), Safeguard Engine, Cable Diagnostics Function, bandwidth control, LLDP support, Port Security, Remote Switch Port Analyzer (RSPAN), SNMP trap, DHCP client, Energy Efficient Ethernet, Dynamic VLAN Support (GVRP), Strict Priority (SP), Loopback, TFTP client, 4MB packet buffer, 802.1x authentication, Duplicated Address Detection, Two Rate Three Color Marking (TRTCM), Type of Service (ToS), Precision Time Protocol (PTP), DiffServ Code Point (DSCP) support, 2 fans, IGMP filtering, Single Rate Three Color Marking (SRTCM), IP source guard, Head of Line Blocking Prevention, host based access control, Priority-Based Flow Control (PFC), VLAN Trunking Protocol (VTP), Bridge protocol data unit (BPDU), Link Aggregation, Management Information Base (MIB) II, Source-Specific Multicast (SSM), Digital Diagnostics Monitoring (DDM), Network Timing Protocol (NTP), Authentication, Authorization and Accounting (AAA), VLAN Double Tagging (Q-in-Q), Loop Guard, Ethernet Ring Protection Switching (ERPS) v2, VLAN mirroring, MLD filtering, Web-based Access Control (WAC), Switch Resource Management (SRM) | Compliant Standards | IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1v, IEEE 802.1ag, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.1AX, IEEE 802.1Qbb | Power | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) | 44.1 cm x 38 cm x 4.4 cm | Weight | 6.3 kg | Manufacturer Warranty | Limited lifetime warranty |
General | |
Max Units In A Stack | 9 |
Encryption Algorithm | MD5, SSL, TLS 1.0, TLS 1.1 |
Authentication Method | RADIUS, TACACS+, Secure Shell v.2 (SSH2) |
Status Indicators | Status |
Expansion / Connectivity | |
Interfaces | 48 x 1000Base-T RJ-45 PoE+ , 4 x 1000Base-X SFP , 4 x 10GBase-X SFP+ , 1 x console RJ-45 management , 1 x management (Gigabit LAN) RJ-45 , 1 x USB 2.0 Type A , 1 x alarm RJ-45 , 1 x console (mini-USB) |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 54.1 Watt |
Miscellaneous | |
MTBF | 199,929.76 hours |
Compliant Standards | FCC Class A certified, VCCI, C-Tick, BSMI, cUL, CB, CCC, ITU Y.1731 |
Software / System Requirements | |
Software Included | Standard Image (SI) Software |
Dimensions & Weight | |
Width | 44.1 cm |
Depth | 38 cm |
Height | 4.4 cm |
Weight | 6.3 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Environmental Parameters | |
Min Operating Temperature | -5 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 10 - 95% |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 5 - 95% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
