D-Link DIR-809 - Wireless router - 4-port switch - 802.11a/b/...
D-Link DIR-809 - Wireless router - 4-port switch - 802.11a/b/g/n/ac
£25.21
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Enjoy combined wireless speeds of up to 750 Mbps and increased range thanks to the latest 802.11ac wireless technology
  • Access your network via two concurrent wireless bands for seamless performance no matter what you are doing
  • Set up the DIR-809 in no time with the web-based setup wizard, and create a secure wireless connection easily using Wi-Fi Protected Setup (WPS) or WPA
  • Type: Wireless router
  • Standards: Ethernet, Fast Ethernet, IEEE 802.11a, IEEE 802.11ac + 3 more
  • Speed: 750Mbps
  • Stock Status: In Stock
Product codes
The DIR-809 Wireless AC750 Dual Band Router is an affordable yet powerful wireless networking solution which combines the latest high-speed 802.11ac Wi-Fi specification with dual-band technology and fast Ethernet ports to deliver a seamless networking experience.
Product Description D-Link DIR-809 - wireless router - 802.11a/b/g/n/ac - desktop
Device Type Wireless router - 4-port switch (integrated)
Enclosure Type Desktop
WAN Ports Qty 1
Data Link Protocol Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band 2.4 GHz / 5 GHz
Data Transfer Rate 750 Mbps
Remote Management Protocol HTTP
Features Firewall protection, DMZ port, NAT support, manageable, Wi-Fi Protected Setup (WPS)
Compliant Standards IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 18.995 cm x 13.297 cm x 0.811 cm
Weight 228.6 g
System Requirements Apple MacOS X 10.4 or later, Microsoft Windows XP SP3, Microsoft Windows Vista / 7 / 8
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link DIR-809 - Wirel...
£25.21
