D-Link DIS 200G 12-Ports Managed Gigabit Ethernet Switch
£431.74
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Durable and reliable design
  • High redundancy and reliability
  • Surveillance traffic optimization
  • Easy troubleshooting
  • Type: Gigabit Ethernet
  • Ports: 10
  • Managed: Yes
  • POE: PoE+
  • Stock Status: In Stock, Used Stock
Product codes
The DIS-200G-12PS Layer 2 Industrial Managed Switch is equipped with 8 PoE-capable 10/100/1000BASE-T ports, 2 10/100/1000BASE-T ports, and 2 SFP ports. This switch features a robust design making it ideal for deployment in industrial and outdoor surveillance settings, capable of withstanding the harshest environments. The DIS-200G-12PS furthermore integrates advanced management and security functions to provide a complete solution.
Product Description D-Link DIS 200G-12PS - switch - 10 ports - Managed
Device Type Switch - 10 ports - Managed
Subtype Gigabit Ethernet
Ports 10 x 10/100/1000 (8 PoE+) + 2 x SFP
Power Over Ethernet (PoE) PoE+
PoE Budget 240 W
Performance Switching capacity: 24 Gbps , Throughput (64-byte packet size): 17.85 Mpps
MAC Address Table Size 8K entries
Jumbo Frame Support 9216 bytes
Routing Protocol IGMPv2, IGMP, IGMPv3, MLDv2, MLD
Remote Management Protocol Telnet, CLI
Features Flow control, ARP support, auto-uplink (auto MDI/MDI-X), IGMP snooping, DoS attack prevention, port mirroring, store and forward, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, Dying Gasp support, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Quality of Service (QoS), MLD snooping, Safeguard Engine, reset button, Cable Diagnostics Function, IPv4 support, fanless, LLDP support, Link Aggregation Control Protocol (LACP), Port Security, SNMP trap, DHCP client, 512KB packet buffer, Dynamic VLAN Support (GVRP), dual firmware images, Strict Priority (SP), tagged VLAN, TFTP client, 802.1x authentication, Ethernet Ring Protection Switching (ERPS), Digital Diagnostics Monitoring (DDM), Authentication, Authorization and Accounting (AAA), Web-based Access Control (WAC), Energy-Efficient Ethernet (EEE), Weighted Round Robin (WRR), Head-of-line (HOL) Blocking Prevention, loopback detection
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
Power AC 120/230 V / DC 46 - 54 V (50/60 Hz)
Dimensions (WxDxH) 21 cm x 17.12 cm x 4.8 cm
Weight 2.5 kg
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been opened but is in excellent condition
Ref: F3XW 041625
£382.74
product
Ref: F3XW 041625
Accessories
Packaging
Functional
Software
Manuals
£382.74
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
D-Link DIS 200G 12-Por...
£431.74
