D-Link DWA-182 Wireless AC Dualband Adaptor
£27.12
Delivery:
Key features
  • Browse,stream and watch online in minutes at the fastest wirelessspeeds
  • Forintelligent, versatile, interference-free bandwidth
  • With all of your current wireless products – no updates needed
  • Wired / Wireless: Wireless
  • Protocol: IEEE 802.11a, IEEE 802.11ac (draft 2.0), IEEE 802.11b, IEEE 802.11g + 1 more
  • Form Factor: External
  • Compatibility: PC
  • Type: Network adapter
Product codes
This USB Adapter enables you to transform your wireless Internet connection by using Wireless AC Technology, the fastest wireless technology available today. You can download web content and synch files to a mobile device up to 4 times faster* than the previous standard, and have extended coverage around your home with fewer wireless deadspots. Get revolutionary wireless speeds which allow you to check your email and surf the Internet or game, make Skype™ calls and stream HD movies to multiple devices using the interference-free 5GHz band.
The latest in wireless, 802.11ac Technology, brings you the fastest speeds, extended coverage around the home and fewer wireless deadspots. Get revolutionary wireless speeds for flawless HD video streaming to multiple devices.. Dramatically improve the wireless coverage in your home, allowing you to watch HD-quality video from more devices, in more places, simultaneously.
Compatible with all your wireless products
While the Wireless AC Dualband Adapter delivers cutting-edge 802.11ac speed to your home network, it's also backward compatible with all of your current wireless products - no updates necessary.
Easy WPS push button setup
Quickly and easily establish a fast, secure Internet connection that will have you browsing, streaming, and watching in minutes. It's as easy as push and connect!
*When compared with Wireless N 300
Product Description D-Link Wireless AC1200 DWA-182 - network adapter
Device Type Network adapter
Form Factor External
Interface (Bus) Type USB 2.0
Dimensions (WxDxH) 9.73 cm x 2.91 cm x 1.35 cm
Weight 20.5 g
Data Link Protocol 802.11a, 802.11b/g/n, 802.11ac (draft 2.0)
Frequency Band 2.4 GHz, 5 GHz
Compliant Standards IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft 2.0)
System Requirements Microsoft Windows 7, Microsoft Windows XP SP3
Microsoft Certification Compatible with Windows 7
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
D-Link DWA-182 Wireles...
£27.12
